Question about Brother HL-2040 Laser Printer
Drum light flash Brother HL 2070N
We changed the drum but the light of the drum keeps flashing.
It prints fine. I tried with the Go button couple of times without results
  • 3 more comments
  • hotchinadoll Mar 15, 2008
    i tried the go button trick still doesnt work i replaced the drum the light still flashes non-stop
  • Pcas Mar 29, 2008
    I have a brother hl-5040 laser printer, I remplace the drum but the light steel on. What's the problem
  • sign1 fixya Aug 24, 2008
    the printer reports being out of toner, despite its being nearly full. removing the toner cartridge and shaking it fixes the problem temporarily (i.e., the printer will print a few more pages perfectly before requiring another shake. this is terribly annoying
  • Anonymous Mar 24, 2009
    Nothing working. toner light on all the time - help
  • Anonymous Apr 01, 2009
    thanx
You need to have the front of the printer open, when you press and hold the 'Go' button. All four lights will come on, in sequence. Release the button, and close the front cover. Done...
Posted on Mar 28, 2008
Open the front drum cover and leave it open with the drum in.
Press and hold Go button untill all lights are on and then let go.
Close the front cover.
It's done
Posted on Jun 03, 2008
    Master:
  • 555 Answers
Press and hold down the Go button for about 4 seconds
until all the LEDs light up. Once all four LEDs are lit,
release the Go button. This resets the 15,000 page drum use counter.
Posted on Feb 27, 2008
  • Matt Jurach
    Matt Jurach Feb 27, 2008
    According to the device manual, this key sequence is supposed to be performed before you replace the drum.
    Maybe try doing the key sequence, then open the printer to remove and replace the drum again? That might do the trick.
Quote "I finally cleared for me when I first took the drum out, left the door open and held the go button down"
ive come across this problem this afternoon and the solution providsed worked fine, thankyou sir. me and my paddawan are very grateful.
Macca, Jobo
Posted on Feb 06, 2009
Cover the circular windows on the side of the printer cartridge with black electrical tape. (The printer uses these to measure the toner level.) Covering them worked perfectly for me.
Posted on Sep 15, 2008
I posted a solution under this link. It'll solved toner LED problem which I had before.
http://www.fixya.com/support/t682623-drum_toner_led_blinking
Posted on Jan 12, 2009
Simpleminduk suggestion fixed it...thanks
Posted on Jun 16, 2008
    Champion:
  • 320 Answers
Are you using oem or generic toner????????
Posted on Jan 13, 2009
Same problem with the Toner light flashing, after replacing Toner (3rd Party purchase, not Brother). None of these tricks work for me either.
Might there be some problem with the new Toner Cartridge?
Posted on Nov 27, 2008
None of these suggestions work.
my lights flash and flash
I finally cleared for me when I first took the drum out, left the door open and held the go button down.
Posted on Aug 20, 2008
  • neldafaye Jun 16, 2011
    That did the trick.
Yes worked thx
Posted on Aug 17, 2008
Brother HL-2070N Laser Printer Will Not Print
First of all, I checked the answers given here, but nothing worked; everytime I turned on the unit, the red light flashed that the printer was out of paper.
From the Brother's HL-2070 manual, in the troubleshooting section: take out the toner cartridge from the front of the machine (be careful, any black toner powder that come off may be very difficult to clean up). I took the toner cartridge to the sink.
There is a blue slide along the top of the unit that will clean the corona wire if you slide it back and forth, from one end to the other (toner/dust can become caked on the wire over time; sliding the slider back and forth simply knocks the caked off 'stuff' off of the wire).
Replace the toner cartridge; it worked fine for me. I was immediately able to print.
Mar 11, 2010 | Brother HL-2070N Laser Printer
My drum light keep flashing. How do i fix this problem?
if the drum light is flashing, and the ready light is on,
it means that your drum is nearing end of life and will need to be replaced soon.
thanks adi
Jan 26, 2010 | Brother HL-2070N Laser Printer
Drum light still on when toner has been replaced
You need to replace the drum and reset the printer for that to go away, open the front door and hold the go button til all lights flash and the drum is reset. If quality is OK you can keep using the old drum. If you press the go button 3 times it will give a report showing the life left in the drum.
Oct 01, 2009 | Brother HL-2070N Laser Printer
Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Sep 26, 2009 | Brother HL 2140 Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Brother HL-2070N red "paper" light flashes after a paper jam
http://welcome.solutions.brother.com
Try this
[LED Indication]
The Paper LED is flashing.
Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document.
Clean drum unit:
The corona wire needs to be cleaned.
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Jan 23, 2009 | Brother HL-2070N Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Brother HL-2040 Laser Printer Logo
21,780 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
