Question about Refrigerators
Zanussi ZNB 3450S Fridge Freezer not cold enough
Hi, for the last couple of days the freezer temperature has been reading as high as -10C, even though it's set to operate at -16C. It "beeps" to indicate that the temperature is too high. The unit was bought in July last year so I'm not too sure where to start.
Also, there is no sound coming from the unit at all, all I can hear is a faint "crackling" - almost as if there is ice cracking, whenever I open the doors. The fan never seems to switch on.
  • CormacM Feb 29, 2008
    So I should empty the freezer and defrost it properly? It's actually reasonably full at the moment.
  • Anonymous Aug 27, 2008
    mine is 18 months old and has just started to show the same symptoms. Set at 18 but alarming out and reading 10 deg, last night it started to make a noise as if a fan blade was rubbing against something? Have switched off a mains for a few hours and lowered the temp but no luck
    Problem Solver:
  • 12 Answers
It is going into defrost,not enough frozen items in freezer to hold temperature down. if you bought it july last should still be under waranty
Posted on Feb 27, 2008
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Hi, my side my side fridge freezer has just packed up, the temp reads cold enough but the fridge and the freezer parts are both warm :( plz help
While it could be the main control board, I would check for a defrost circuit failure first. If you take off the read shield of the freezer you will be able to see the evaporator coils. If that is a block of ice, then your defrost circuit is not doing its job and the ice is causing the thermostats to read the incorrect temperature.
The good news is that once you defrost the unit, you will have 2-3 weeks before the ice builds up enough to be a problem again. Which give you time to troubleshoot and order the replacement parts.
Jan 28, 2012 | Samsung Refrigerators
Hi I have a side by side fridge freezer and my refridgerator temperature is 10c i have the temperature set at 7 the highest. It was at 6 but it wasn't getting cold enough. Can you please help. thanks...
Sherree, do this simple check open your freezer door and feel the back panel in your freezer section. If you feel frost on it then a repair is required of the possible of 3 items that could have failed defrost heater, defrost bi-metal thermostat, or defrost controller and is going to require disassembly of the freezer panel and electrical checks as well as the defrost controller. but if it can wait until monday then a serviceman can diagnoise the problem and repair it.
Feb 27, 2011 | Maytag Refrigerators
Faulty Freezer & Fridge
You have a defrost or temperature control issue or both. I will be back soon with photos and solutions. Thanks, Sea Breeze
Jul 13, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
Aug 30, 2008 | Zanussi ZEBF277W Bottom Freezer...
The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Apr 13, 2008 | Zanussi ZEBF277W Bottom Freezer...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Refrigerators Logo
281 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
