Question about GE GSS25IFPCC / GSS25IFPWW Side by Side Refrigerator
Ice M. Works but Water does not
Can you tell me what my problem is if my ice machine works fine but my water dispencer does not. When I try to use it I hear it clicking like it wants to work but no water comes out. Please E-mail me at samuel.cepeda@level3.com Thnaks
  • 1 more comment
  • luishern Mar 05, 2009
    I have the same problem. I know I am getting water to the refrigerator door because I have taken the hose apart after the filter and when the dispenser is pressed water comes out. The problem is in the door. Not sure if there is a valve of some sort in the door or could it just be a plug in the water line.
  • 68poorboy Mar 14, 2009
    my problem is in the door but i cant seem to find a way to get inside to fix it,i get water up to the line goes in the bottom of the dooe and i have fead a wire up as far as i could( 3feet ) to check for a block but it stops behind the unit, how do i get into the door
  • luishern Mar 19, 2009
    I am thinking that since the water and ice distribution is in the freezer door, the water line might be plugged with ice. I am going to shut off the water and disconnect the water line to the door and see if it melts. I had this problem before and had the freezer door open for a while trying to fix it. After I put everything back together it started working . I think I just gave it enough time to thaw out.
    Problem Solver:
  • 12 Answers
Water inlet is stopped up ,or has gone bad. the valve is located behind the box ,where the water supply line is hooked up
Posted on Feb 27, 2008
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Ice maker not working
Cause could be the solenoid valve which controls water flow into the ice maker.
Could be bad solenoid, bad relay for solenoid, clogged solenoid valve, corroded electrical connections, etc.
More info? Let me know...
Charlie
Aug 14, 2009 | Refrigerators
No ice from ice maker
sounds like the inlet valve is defective. you should have a dual water inlet valve, one side for the dispencer and the other for the ice maker. I would check to be sure the inlet for the icemaker is not clogged, also check to be sure that ice has not clogged the water line near the ice maker, or the valve could be defective.
Feb 20, 2009 | Frigidaire Refrigerators
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Water Dispencer not working.
check your freezer for ice. do you have alot of ice in your ice maker tray? if so your water line could be frozen. try to self defrost the freezer for about 3hrs to thaw out the water line. check your water valve also. when you call for water do you hear a humming or buzzing noise? on ge fridges ive worked on if you hear a humming noise when calling for water, most likely your water valve is ok. trace the water. meaning where does the water start? at the wall then through a hose then to your valve which is behind fridge on bottom. trace the hoses and you will find the prob
Feb 09, 2007 | GE GSS20IEP Side by Side Refrigerator
GE GSS25IFPCC / GSS25IFPWW Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
