Question about Dell Dimension 5100 (D51L1) PC Desktop
Hard Drive Upgrade on Dell Dimention 5100 Desktop
I want to upgrade my hard drive on DELL Dimension 5100 Desktop. Can you recommend brand and specs for the hard drive that will be compatible with my PC.
Sincerely
Bhairav Mehta
    Genius:
  • 3,587 Answers
Are you replacing it, or simply adding one to your desktop?
best place to get that information is www.dell.com
click on accessories
Posted on Feb 27, 2008
What is the maximum drive size I can install on my SATA controller?
Looks like at least 400Gb see below.
Product Details for 5100 400Gb Desktop SATA Hard Drive This SATA Hard Drive is used and has been tested for proper functionality.
Dell Dimension 5100 400Gb Desktop SATA Hard Drive.
Hope that helps.
Feb 25, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
When I start up my Dell Dimension 8250 (Windows
Sounds like the machine got stuck in the middle of a installation of windows. Best thing to do is to reinstall windows and let the cd format the hard drive, if it can't format the hard drive then the hard drive is bad and would need to be replaced.
Apr 23, 2010 | Dell Dimension 8250 PC Desktop
Upgrade my Dell Dimension 4400 Service Tag 43L5811
You can upgrade to practically the maximum available amount of harddrive space as long as the new drive is IDE. The following picture shows the drive you require:
A guide to replace a hard disk for this PC is available here.
As a rule of thumb, you should buy the maximum size hard disk you can afford as it improves the performance.
You can choose from any brand but choose the one with maximum warranty.
PS. There is no need to go into any kind of numbers; just ask the vendor to give you a certain size IDE hard drive eg a 250GB Western Digital IDE hard drive.
Mar 08, 2010 | Dell (078FN) ( 078fn ) 9.1 GB...
Looking for what kind of processor upgrade
Well it seems you can go up to at least a 3.6GHZ processor. It is socket 775, so any Processor that will fit will in all likelihood work fine. As for the hard drive well I like 7200RPM 8MB Cache 3GB/sec SATA drive. or similar spec, & truthfully one brand is as good as another... But if forced to say.. well Seagate.
Also if you want a fast machine RAM as MUCH as you can put onboard and afford.
I have found a manual here for you. http://support.dell.com/support/edocs/systems/dim9100/en/D86630LRs.pdf
Feb 03, 2010 | Dell Dimension 9100 PC Desktop
Hard Drive Upgrade
Yes, the motherboard should support that size drive with no problems. You will have to reinstall windows using the discs that dell sent you originally. Be aware the drivers for dell can be tricky to reinstall.
Oct 29, 2009 | Dell DimensionTM E520 PC Desktop
Hard Drive, 80GB, I, 8M, 7.2K Serial ATA, Maxtor-Calypso I want to upgrade and I can't find specs on my hd. can you help me find them?
http://episteme.arstechnica.com/eve/forums/a/tpc/f/24609792/m/219000534831
cut and paste this link and you will find some usefull information.
Sep 26, 2009 | Dell Dimension 4600 PC Desktop
New hard drive choices
Hello, Bob!
Seeing as I am a 6 year veteran of Dell Tech Support, I should be able to help you out, no problem.
One thing that I would like to let you know is this: according to Dell Support Policy, you ARE allowed to put a non-Dell-branded hard drive in your computer. However, if Dell Support deams that this non-Dell hdd has caused another Dell component to fail, they will not replace the defective product. BUT, since it is HIGHLY unlikely that a non-Dell hdd would actually cause any other failure, feel free to purchase a non-Dell hdd. (I often times suggested that customers take this route because unless you're purchasing a refurbished Dell product, you're only paying for the Dell name.)
Anywho...
There really are no limitations to what size hdd you can install in your computer. Of course, a larger hdd will take more time to process information (Basically, there's more surface area to scan when your computer is searching for a specific piece of information.). Your main thing will be determining if you have an IDE hdd or a SATA hdd.
The Dell Tech website CAN be your friend (support.dell.com). From there, you can view original configuration and even available upgrades simply by entering your service tag (Usually found toward the back of your computer, on a black sticker with white text. It should list your service tag, an alpha-numeric value, and express service code, an all-numeric value).
If I were in your position, I would most likely not go over a 160g or 200g hard drive... simply to keep decent performance.
Hope I helped!
Oct 29, 2008 | Dell Dimension 8200 PC Desktop
Slave drive into Dell Dimension 5100
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Jun 07, 2008 | Dell Dimension 4600 PC Desktop
High Hard Drive Temperature
you can check zalman's homesite. http://www.zalman.co.kr/eng/main.asp
I can recommend them to you.
CS.
May 16, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Upgrade
according to this cnet.com (http://reviews.cnet.com/desktops/dell-dimension-5100-pentium/4505-3118_7-31429803.html) the dual core is not an option. I'm not sure if that means that Dell doesn't offer an upgrade, or if it's not possible. First, open your tower and look over the Motherboard for the manufacturer and model. Once you have those, google them and look for the specs of what cpu's are supported by that motherboard. If you can and do decide to upgrade, check with the CPU manufacturer to see how strong of a power supply you need for the more powerful CPU. You're might be ok, but you might need to upgrade the PSU (Power supply) with the processor. From your description, I can't tell what motherboard is in your Dell. That will be the limiting factor. Get the motherboard specs and you'll know what you can do.
Sep 04, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
117 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
