Own a Maytag Washing Machine Model No. LAT9416AAE I overloaded with a extra large comforter. I started the cylce and went upstairs to my room leaving it unattended. My parents were down stairs With it, and next thing I know, My dad is yelling at me that I broke the washer!!!The belt I'm sure is probably ruined because the smell of burnt rubber was heavy in the air. My father had smelled the rubber stench and ran to the machine and shut it off! But after we Unloaded the comforter from the machine and bucketed out the water;we tryed to restart the cycle it fill with water, but absolutely dead after that, Would it be the over load protector I see in the wiring schematics? and if so where is it ocated exactly, and also how and were to replace the belt? Help Please!!!!!!
I have the same problem except mine has a transmission no belt my wife was doing a wash BIG COMFORTER !!! it filled and that was all she wrote . i ripped everything apart looking for the overload protector after reading this i see its in the motor where is the balance switch located?
thanks
Posted on Jan 31, 2010
  • 164 Answers
There is a thermal overload protector in the motor. After the motor cools it should restart. There is an off balance switch that might have been tripped when pulling out the comforter or when bailing out the water. As for the belts, tip the machine back and you will see the belts underneath the washer. Very easy to change and you'll see what I mean when you see the belts. That should solve your problem. AND DON'T OVERLOAD THE WASHER AGAIN.
Posted on Feb 28, 2008
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
I have a maytag washing machine (model- LAT9416AAE) that will not drain water. It was a small load and at the end it did not drain.
This is your drain pump that is out. This is a fairly easy repair to make.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.
Thanks, Ella
Nov 11, 2009 | Washing Machines
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Water leaks when filling
Use a putty knife at the top front corners to release the spring catches. Lift up the top. Examine the plastic thing that delivers the water to the tub, it may be cracked or out of place.
Apr 05, 2009 | Maytag LAT3600A Top Load Washer
Leaking
Sheets Or Comforters? This Normally Occurs With An Overload Such As Pillows And Comforters Due To The Large Circumference. Which Simply Means That Anything That Has A Large Area Will Make The Water Come Over The Top Because When The Machine Is Running The Spin Cycle The Large Area Of Fabric Covers The Side Of The Machine. Actually Causing Water To Spin Off The Top Of The Fabric And Over The Sides Of The Washing Machine Bucket Thus Ending Up On The Floor Below.
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing down comforter
It really depends on how big the drum is. It needs room to wash properly, so if there is no room - I would say it's too big.
Try your local laudarette - they have industrial machines that are designed for large items, so to save yourself a repair bill - just use them.
Nov 15, 2008 | LG WM1812C Front Load Washer
Size of washer
Size varies between manufactures, the biggest I have seen is the GE which is 3.5 cu ft, base your machine on your standard size load, ours is about 8lbs however I dont overload, I take large items quilts, comforters etc to a laundromat, its not worth breaking my machine over a comforter wash for $3.50 American.
Go to Sears.com and look @ the washers available
Jun 06, 2008 | Kenmore 22422 Top Load Washer
Washing machine not working
You probably burnt the belt. Take the front panel off, two screws at the bottom and let the motor cool off.
Increase the water level and then turn it to spin. see if it pumps out.
The belt will need to be replaced.
May 25, 2008 | Amana ALW880WH Top Load Washer
Washing Machines Logo
358 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
