Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've
never found a good solution to lightning-fried electronics (random
power supply components are destroyed and/or fuse blown), other than renters insurance or
homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
turns out it was the battery. Once the battery expires, the UPS goes "dormant" the first time it switches to battery. Old battery had expanded, maybe from corrosion inside, and took considerable effort to pop out. Miraculously, replacing the battery has worked so far.
