Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Toshiba 42hp83 Custom installer... installed 3 years ago, 2 months later tv failed, had authorized dealer repair under warranty, they said they had to remake all the solder connections (bad from the factory). Worked fine for a little over a year, now the tv works fine for about 20min, then the picture pixelates and eventually turns black. If you change the channel or turn it off and on again, it works for a minute or so then does the same thing. I just need to get some idea of what it will cost to fix or if it's not worth it I'll junk it. Thanks for your help
  • 1 more comment
  • x-tremewire Feb 27, 2008
    Is there any way I can test these items myself? I have the service manual, which doesn't really say a whole lot other than the locations of these boards, and am an experienced electronics tech (not with tv's though) I have a full suite of sencore equipment at my disposal. Thanks for your help.
    Thanks. The audio does work fine under all circumstances. Is there a way you can check the flyback autotransformer or the horizontal amplifier with a meter? I hate to just start replacing parts and not knowing if they are bad. Thanks, Ken
    Thanks for all the good advice, you guys have been more than helpful for the $9.99 you charge. One more question... If you had to start replacing components, which ones would you start with if you were me, or would you just take it somewhere, or would you junk it and buy a new one. I could spend $400 on this tv at the high end, and if it works it would be worth it... but seeing as you can get a new 42 for a thousand bucks, I'd hate to waste $200 for someone to diagnose it and tell me it's going to be a $600 or $700 repair which I wouldn't spend the money on. Obviously I'd like to spend as little as possible. Again, thanks for your help.
    Genius:
  • 3,422 Answers
The repair will cost anything between $200-300 or may be more.When the audio is working and the picture is dark (loss of raster), the problem is almost always (but can be many other things) either a bad flyback autotransformer (which generates the high voltage for the picture tube) or the horizontal amplifier (which drives the flyback).
Here are few more troubleshooting steps you can try:
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
Goodluck..
Posted on Feb 27, 2008
  • Priya darshan Feb 27, 2008
    If it is still under warranty then i suggest you to get it replaced or repaired by them.
    IB4G2008 can help you with that better.
    Brigadier General:
  • 3,614 Answers
You can still fix it, the problem came out the same as like the problem before, could bepossble that the soldered one has loose again. I can't give you a exact rate it will be depending on the work to be done on your TV. Just send it to authorized service center to be fully checked and correct the problem. An exact parts can still be available to them.
  • micromaster
    micromaster Feb 27, 2008
    Buy a new one, no more maintenance, & no more problems, less wrinkles.
    Genius:
  • 3,587 Answers
Well...from what you're saying, it appears that you're at the front edge of a major board failure, most likely the system controller/video board..could be power supply too.
  • 2 more comments
  • Patrick Michaels
    Patrick Michaels Feb 27, 2008
    costs will range around 300 to 400 for the parts, and depending on where you are, around 50 to 100 per hour(figure two hours minimum) for the labor..
    so, you're looking at around 500 or 600 easy to get it back on it's feet, assuming it's only the boards, and not the main screen itself.
  • Patrick Michaels
    well..the signal interface is the whole issue here. Unless you can simulate those signal paths, and have a sequence diagram(usually reserved for the factory techs) then you'll be flying blind. The signal/voltage levels usually don't appear in the service manuals, since so few folks do component level testing or troubleshooting any more. It's all board swapping these days.
  • Patrick Michaels
    the flyback transformer generates a high voltage, which requires a special device for measurement, for isolation purposes.
    I admire your interest in doing all this yourself, yet you would be best served when you have a full service manual, which you can purchase online. To suggest that a five dollar set of helpful advice, replaces that sort of information, is inspired.
  • Patrick Michaels
    Patrick Michaels Feb 28, 2008
    so, now that you've gleaned some of the best information, are you going to decide who's advice helped the most?
I had purchased new pulsar as 150 5 months ago but for last 3-4 months i found jerking problem at 25-35 speed. I took my bike to showroom but they also failed to solve my problem. Pls give me solution
as it is new and still under warranty , take it to a service dealer or authorized service agent for warranty work
any work you do will void warranty
Oct 21, 2016 | Motorcycles
Check airflow sensor turn tv off
Your TV needs the modified temp sensor installed by Mits authorized service center. It's covered under extended warranty for 3 years after date of purchase. Repair takes about 20 minutes and not too expensive if you're out of warranty period. Part #299P313010A
Bill W
integrityhomeworx.com
Mar 08, 2011 | Mitsubishi WD-57731 57" Projection HDTV
My Toshiba 42hp83 has a rectangular area of the screen that changes colors randomly from the left-center of the screen down to the bottom. After about 20 minutes of the TV being on, the problem usually...
We had a similiar issue with our SAMSUNG Plasma TV. It had a 2'or 3" vertical bar of random colors on the right side of the screen. It would also go away but then come back. Fortunately for us the TV was still under its original 1yr manufacturers warranty. We called the customer support and they scheduled a service call. The TV repair man took our TV to the shop and replaced the defective components. It took about 3 weeks for the repair.
Nov 06, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
My touchpad in my toshiba computer is not working. i purchased my computer two months ago. what should i do
You are still in warrenty, go to Toshiba website and get to customer services. Also - as its under 3 months you could take it to where you purchased it from and they should sort it, dont let them tell you to go to the manufacturer as in the legal sense they have a duty to you as you purchased from them and it's been under 3 months.
DONT open it up or let any technician open it up while its in warrenty, that will void the warrenty.
Oct 29, 2010 | Computers & Internet
ENGINE REBUILD WARRANTY???
Sorry, most warranties only cover original repair and no warranty repairs after that. In other words warranty doesn't get a new start date. This is not what you want to hear but as I am in the industry that is the usual wayit operates... Unless you can talk them into extending another year or two....
Sep 09, 2009 | 1997 Ford Thunderbird LX
Blue Haze in middle of screen progressively getting larger
This one is easy. WHen this happened to me, I simply called GE extended warranty service up and bought an extended warranty. I waited 30 days and called them up with my problem. A repair man showed up a few days later with the 1200 dollar light engine and installed it and left. Then I called GE up and cancelled the warranty. Total cost?: 48 bucks
May 30, 2009 | Hitachi 50V720 Television
Disc error on Husqvarna viking sewing machine floppy
sounds like a bad disk or the floppy drive is going out. The floppy drive is very expensive to replace. It may be that a local dealer has a used floppy drive which they will install at 1/2 price. If you determine that the floppy drive is at fault, take it to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you. If you are the original owner and you purchased it less than 5 years ago, the drive may be under warranty and you would only pay for the labor.
Mar 27, 2009 | Husqvarna Viking 1
3 months ago Led blinks 7 times now Led blinks 6 times
Sorry to hear that. You could fix it with Best Buy or the warranty service repairman recommended by Panasonic.com
I have a client that had used one of the panasonic repairman to fix the same problem that you have about a year ago,the TV is good ever seen.
I am in the A/V installation business, my recommendation(Pioneer Kuro Plasma TV or Sharp LCD.)Very good track records from my clients.
solutiondoct
Nov 03, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Authorized Repair Centers for Akai Flat Panel TV
My 42 inch Akai is about 6 months old,, and is showing green where black should be..
BUt there is help for you all.. Call Verizon, sign up for their "Expert Care" program. it's $10.00 a month, and active after the third month.
with a $75.00 deductable. THey will fix or Replace (give you choice of three alternate models/brands).
Free services under this plan are adjustments, and One FREE remote per year!.
i recomend you sign up for this program, and after 90 days. call for service. They more than likely will replace your TV's.
This is what they did with mine..
ALSO.
it doesn't matter how old your TV is, the plan is applicable to all TV's in your household. So one plan, one monthly payment of $10.00, covers all the TV's you own!!
Dec 09, 2007 | Televison & Video
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
