Question about Lexmark X2470 All-In-One InkJet Printer
Lexmark x2470 printer
It is cuwing the paper and does not want to print
Lexmark x2470 all in one inkjet printer installation does not show on desktop
cuwing the paper and does not print
not sure of printer settings
scanner does not work
fax does not work
please help
mary
Posted on Oct 24, 2008
    Genius:
  • 3,587 Answers
We have a link on how to fix your own printer through this link(check for search box further down page)
Posted on Mar 20, 2008
Cannot get Lexmark X2470 to print.
Uninstall the firmware with revo uninstall, install the latest firmware.
Ink? connection? Paper too much or too little
Regards
Sir Dana Taylor
Mar 16, 2017 | Lexmark X2470 All-In-One InkJet Printer
Paper slipping Lexmark X2470
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Apr 10, 2012 | Lexmark X2470 All-In-One InkJet Printer
I lost my installation cd for my x2470 printer. I do not have money,is there a way to install it witout a cd
    • Step 1 Open your web browser and go to Lexmark's "Drivers and Downloads" page (see Resources section below). Locate the search box labeled "Search by Model" and enter X2470. Press return. Select your operating system from the pop-up menu. Wait for the download page to load, then click the "Download Now" button. Save the installer file to an easily accessible location.
    • Step 2 Rotate the printer so that the rear section is in view. Connect the power cord to the power cord connector located on the right. Plug the remaining end of the power cord into an electrical wall socket. Connect one end of the USB cable into the USB port located on the left. Rotate the printer back into place.
  • Step 3 Turn on your printer. Extend the paper guides and insert paper into the tray. Readjust the paper guides so that they are flush with the paper.
  • Step 4 Lift the scanner unit and wait for the print cartridge holder to move into view. Push down on the light blue lever to raise the cartridge holder lid. Install the ink cartridge into the print cartridge holder. Close the cartridge holder lid and lower the scanner unit.
  • Step 5 Connect the remaining end of the USB cable into any available USB port on your computer. If any "Add New Hardware" screens appear on your computer, click "Cancel."
  • Step 6 Open the previously saved installer file and follow the onscreen instructions.
  • Step 7 Locate the button on your Lexmark X2470 that looks like an open scanner pointing to a computer monitor. Press and hold this button for three seconds. Follow the instructions that appear on your computer. Once this is complete, your printer is ready for use.
May 23, 2011 | Lexmark X2470 All-In-One InkJet Printer
I have a lexmark x2470 printer.i would like to know whether it as one cartidge or two cartridges.please let me know if it is available in indaia
HI,
Please note that the #2 cartridge is the starter cartridge and the after market cartridge is the #1 cartridge.
The Lexmark X2470 printer uses the #1 cartridge which prints both color and black accordingly. While printing black it uses processed black. Hence, to print color images in "Black Only," please follow the steps given below:
1. Click on "Start," "All Programs," "Lexmark X2470 printer" group and then "Lexmark Photo Editor."
2. Click on "File" and then "Open" to select the color image file.
3. Click on "Image," "Mode" and then select "Grayscale."
4. Click on "Print."
This will print the image in gray.
Sep 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
Lexmark x2470 won't feed paper
Good day, this is my advise to you. press the power button off and firmly grasp the paper and gently pull it out and press the power button to turn the printer back on. hope it will help you.
have a nice day.
Jul 27, 2010 | Lexmark X2470 All-In-One InkJet Printer
Hi, replaced ink cartridge on Lexmark X2470. Now it goes as far as the "print alignment page" and freezes. Will not print the alignment page or any other page for that matter. Thanks.
Hello. The ink cartridge may not be seated properly in the carrier. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer asks for the cartridges, reinsert the cartridges. Also, make sure you're using the compatible ink cartridges for the printer. Let it print the alignment page all the way without cancelling it to align the cartridges properly. Hope this helps.
Mar 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2470 printer wont print/connect time executable stopped
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Lexmark X2470 All-In-One InkJet Printer
Printer
have you checked that the printer has no paper bits jammed inside of the printer thats stopping it from loading paper.
or you uninstall it and reinstall see if that helps.
riz.
Apr 03, 2008 | Lexmark X2470 All-In-One InkJet Printer
Paper jamming
Look for some foreign object in the paper path. Easiest way is to turn the printer upside and shake it. (carefully :-)
Aug 31, 2007 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
