Drain and spin cycle
I am unable to use the drain and spin cycle. Somebody please help.
My washer will not drain. It spins and sounds normal, but the tub is full of water. It is a front loader. I have tried to rerun the entire cycle. I have also tried just setting it for "final spin." Nothing seems to work. Please help!
  • rlfie Feb 27, 2008
    It is a Kenmore front loader. The model # on the machine is 417.42042100. It was purchased in early 2002. Thank-you for your help!
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    What is your model number and/or brand of washer? I'm familiar with most Kenmore, Whirlpool, GE and Fridgidaire model front loaders.
  • 5,911 Answers
Okay...the problem may be that you have something caught in the drain pump preventing the impeller from turning. Or, the pump itself may have stopped working. If you experience a problem where the washer does not drain or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Please read ALL instruction before attempting.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the screws at the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located under the wash tub (it is the only pump this washer has).
4. The pump can be removed and the housing taken apart to clean out the impeller trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and place them under the pump. Remove one of the drain lines and allow water to drain. If the tub is still standing in water (as you stated) bail as much from the tub before removing the drain lines from the pump (if you are using the towel method for collecting water).
6. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the housing cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select a wash cycle. Allow the tub to begin filling and check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping.
10. If there are no leaks, you can stop the wash cycle at any time and select a drain cycle. If the drain pump works normal, reinstall panel and tighten screws.
11. If your pump still does not run, more than likely, the impeller motor is damaged and the entire pump must be replaced. The motors typically are the part that fails on this pump. Follow the previously mentioned procedures for removing water from the wash tub.
NOTES:
a. Your pump is item #916709 at repairclinic.com. Or part number 134051100 at searspartsdirect.com. Just type in your model number in the search menu and a parts index with pricing is made available to you. the pump is listed as an "askoll pump" under the "Tub" header at the Sears website. HINT: Sears has it a little bit cheaper.
b. It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
I hope this information is helpful. If you have any questions/concerns, please post back with your comments. Good Luck.
Posted on Feb 28, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Kenmore washer needs two spin cycles
Have you checked the timer? Sometimes the little motor inside of it gets stuck or the concacts become burnt.
Good luck,
Marty
Jun 21, 2014 | Kenmore Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Started normal cycle then gets to drain and spin clothes are still wet
Hello there:
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt, a worn clutch , or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. then retry ok
Oct 07, 2010 | Whirlpool Washing Machines
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Feb 15, 2009 | Kenmore 23822 Top Load Washer
If the washer drains but does not spin or agitate and the belt is o.k. then it is probably either the motor or the electrical connections to the motor.
Nov 11, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
406 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
