Question about Linksys WRT54GL Wireless-G 54Mbps Broadband Router w/Linux all-in-one Internet-sharing Router With 4... (WRT54GV4)
Limited connection on wireless signal
Well i generally dont use my wireless a whole lot but now that i got a laptop, a nintendo wii, and an itouch i want to use it more now.
constantly i get on for like a few pages and as soon as i click to go somewhere ive lost the connection, i see the network connection in the dialogue box and it says 100 percent but my periphals will not connect. I dont have wep on, i have the latest firmware, ive rebooted,renewed,released and nothing. sometimes i connect and sometimes i dont. my itouch always says it cant find the server and once every so many minutes i connect but i take it anywhere else i have no problem, same with the laptop...the wireless in my house is just not working like it should. The one button easy setup is not making this easy at all.
jeff
  • 55 Answers
1. Try to reset your router to a factory defaults.
2. Try to change the wireless channel
3. If you have a 2.4 GHz phone in your house, it might interfere with your wireless network since it's using the same frequency.
Regards
Posted on Feb 29, 2008
Can't connect to server. Error code 52230 comes up.
Here are some troubleshooting ideas:
Error Code: 52230
Unable to connect to your wireless network
Likely cause: Your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii.
How to fix: Manually assign an IP address and DNS to the Wii.
The address below will show you how to manually assign an IP
http://en-americas-support.nintendo.com/app/answers/detail/a_id/3068
Other suggestions:
  • Did this connection used to work but has suddently stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the router back in. Wait a couple of minutes for it to initialize, and try to connect the Wii console online and test for proper response.
  • Check for wireless interference, which can affect the signal strength to the Wii console.
  • What to Do:
    • Check the location and distance of your wireless router.
      The further a device is from your wireless router, the weaker it's signal strength will be. If your wireless signal has to pass through any walls or floors, this will also weaken the wireless signal strength. Move the router to a central location within your home and as close to your system as possible.
      Additionally, if your router is on the floor, moving it to a higher location can improve the signal strength.
    • Change the wireless channel your router is broadcasting on.
      Wireless routers can broadcast on a variety of channels. Sometimes a specific wireless channel may experience interference from other devices and routers nearby. How to
    • Move any metal objects or electronic devices away from your Nintendo system and wireless router.
      Metal objects and electronic devices may interfere with wireless signals. If you have any of these, such as filing cabinets, speakers, power strips, glass, or cordless phones, next to your system or wireless router, move them away.
Nintendo Customer Service Nintendo Wi Fi Connection Error Code Results
Sep 30, 2015 | Nintendo Wii Console
How do i connect the internet to the wii???
Here are step by step instructions on how to set up your internet connection. Please note, the Nintendo Wii connects to the internet via wireless signal, so you must have some type of wireless router or wireless internet connection to connect to!
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Sep 04, 2011 | Nintendo Wii Console
Having trouble connecting my wii to the internet so i can use netflix
Here are step by step instructions on connecting your Nintendo Wii to the internet. Please note you must have a wireless internet connection available to you, the Nintendo Wii only connects to the internet via wireless signal.
How do u get internet on your wii
Here are step by step instructions on how to connect your Nintendo Wii to the internet. Please note you will need access to a wireless internet connection, or must have a wireless router in order to connect your Wii to the internet. The Wii only connects via wireless signal!
Im tring to connect my wii to my aunts laptop next door wirelessly and it will get the signal but it just gives me a code or says try again later
check the laptop's firewall settings because it might be blocking your wii from gaining access to the internet connection
Feb 17, 2011 | Nintendo Wii Console
How do i get wii shop chanel
Hello
To get to wii shop channel first you need to configure your system
Configure your Nintendo Wii for a wireless Internet connection. The only way to access the Wii Shop is by having an Internet connection and a wireless router. The Nintendo Wii has a built-in wireless router that can pick up signals from wireless Internet connections. Make sure that your wireless Internet router is close enough so that the Nintendo Wii can pick up a signal.
Loading Wii Shop;
Use your Wii remote to select the Wii Shop from the main Wii channel menu. The Wii Shop is located in the top right-hand corner of the screen. If your Internet access is not set up yet, then you will be prompted and automatically brought to the Internet Configuration menu. Once your Internet is set up, you will either be brought back to the Wii Shop or the main channel menu.
Navigating the Main Menu
Look at the main Wii Shop menu. Here you will be given two main options with a couple of general options at the bottom of the screen. The first option is to look for games for the virtual console. The Virutal Console contains games from past systems like Turbo Grafx 16, NEOGEO, NES, Super Nintendo and Nintendo 64. Once you have loaded the virtual console menu, you can search games by most popular title, new titles, system, genre or price. When you have found a game that you are interested in, press the "A" button to see a more detailed description with a couple of screen shots, and find out how many Wii Points the game costs.
Wii Points
Purchase Wii Points directly through the Wii Shop by using a credit or debit card. You will use the Wii remote to point and select all of the card holder information. The minimum amount of Wii Points you can buy is 1,000 for $10, so if you want a game for 700 Wii Points, then you will have 300 points left over for future purposes. Instead of using a credit card through the Wii store, you can purchase a Wii Points card at a local retailer. These cards come in different point values, and 100 points represents a dollar.
Downloading the Software
Finalize your game purchase by confirming how many Wii Points will be deducted from your account. Once you have done this, the game download will begin. While it only takes a few minutes to download, you can see the progress by watching a Mario character jump and hit a brick. Once he has reached the third brick, your download is complete. From there, you can continue to shop in the Wii Shop or play the game.
Wii Ware
Check out the other option that is labeled as "Wii Ware." Wii Ware is a lot like the Virtual Console, but everything created here is new and original for the Wii. You can get updated channels like the new Photo Channel or get exclusive Wii Shop games like "Midnight Pool" and "Family Table Tennis." The games here actually are interactive Wii games, and you can get the full game for a lot cheaper than a new Wii game from a store.
Oct 10, 2010 | Nintendo Wii Console
Why do I get an error code when trying to download a game to my Wii Memory?
Any time I have tried to download from Nintendo Shopping channel, I have gotten an error for one of a few reasons. 1. No Internet Connection. 2. Slow Connection, 3. Connection Drop. or 4. operating system error.
If you provide the error code or look it up on Nintendos website, it usually gives your some hints to fix your issue.
However, here are the most common:
1. This is usually because the WII console is not connecting to the router or getting an IP address. If could also mean your router has lost its connection to the internet (easily checked with any other computer).
2. This is usually due to congestion (per Nintendo) in your area. They say to try changing your channel for the router. I think Nintendo recommends 6 or 11 but it depends on how many people in near you use wireless.
3. This can be a number of things. This time of year, you typically have problems accessing/downloading things from Nintendo just because a lot of people are trying. However, I have wireless N and the WII is wireless G; I have found that sometimes causes drops. Wireless N is constantly trying to get the best signal and sometimes changes channels (at least mine does), this can cause G to drop sometimes. I went to a wired solution, it helps in online play.
4. I have not seen this one of late. But when WII first came out, an update disabled WII connect and Nintendo had to replace the unit.
Jan 01, 2010 | Nintendo Wii Console
My itouch won't connect with my wireless network in my home. I have a Netgear router. My ITouch has been working (connecting) for over 6 monts without any problems. Nothing has been changed. All other...
I would turn your itouch on and tap the top bar where the battery and signal show.
a screen will pop down and show your wireless connection. tap it ans check your settings.
make sure you renew lease on your wireless and use the wep code which is on the label of your wireless router.
you should have signal now
good luck
Jun 01, 2009 | Apple iPod touch
Limited connectivity
Your router may be configured to "connect on demand". Enable the setting called something like "Keep Alive"
Jan 02, 2009 | Linksys Wireless-G Broadband Router
Wii internet
What do you mean by "normal" internet? If you download the full version of Opera's browser in the Virtual Console's "Wii Ware" section you can do lots of things that you couldnt in the demo version of the browser.
Sep 03, 2007 | Nintendo Wii Console
Computers & Internet Logo
82 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
