Question about Krups ProAroma 453-42 Coffee Maker
Krups 453 coffee maker - won't to brew/heat
Howdy:
I have a Krups 453 coffee maker that will not brew or heat water. I've taken it apart and have looked on the bottom at the heating plate and track the conductivity to a switch of some sort that has a connection on each end and appears to be some sort of thermal switch. I surmise that this is broken and is sending a signal that says that the plate is hot enough and the machine does not have to brew or heat.
I cannot find a service manual or parts diagrams so I do not have anything else to base my guess on. Any suggestions out there as to what I can do? The darn thing cost $120 and I think it's would work if I could just replace a part but I can't seem to get anywhere. I traced the conductivity to this switch and I have power on one side and don't have power on the other side.
Thanks in advance!
Timv
  • 4 more comments
  • mwdragon Mar 03, 2008
    I have EXACTLY the same problem...occured @ almost the same time. It's a great unit, & would hate to loose it due to such a simple failure
    Michael in Baltimore
  • MarkEBoy Apr 26, 2008
    My Krups 453 won't brew, but the red light flashes. Cannot find troubleshooting help for solution. Could this be the same thermal circuit-breaker problem?
  • elkitz Oct 29, 2008
    Same problem - thermal fuse is open.
  • cwebbles Nov 19, 2008
    I've got a 453 - at least 10 years old. It's not heating and brewing,though all the clock and other settings seem to work. I unplugged it for awhile and plugged it back in. No change, except the indicator light is blinking red/green. I'm assuming its the thermal fuse mentioned below, but haven't seen any reference to the mysterious blinking, so thought I'd ask, just to make sure,
    I've also got a 453 - at least ten years old - that will no longer heat or brew. I'm assuming it the the thermal fuse issue mentioned below, but the indicator light is blinking red/green, and I haven't seen any reference to that, so I thought I'd ask to make sure.
    Thanks
  • drositano Dec 27, 2008
    I had the same problem and called Krups' customer service line. They referred me to a local factory authorized repair place and when I called the guy diagnosed it immediately. This is fixable, it is the fuse. So don't scrap this great cofee maker. I just sent mine in for repair. Also note that he said mine lasted so long because I did not have it plugged directly into the wall, but rather into a plug strip.
  • 4 Answers
I just had the same failure, but fortunately, had already bought a used 10-cup unit a few months back as a spare.
The component in question is a thermal circuit breaker, of the sort which does not reset. Once activated, it is destroyed,
I have been unsuccessful locating the same component on the internet, but it seems to be a very high temperature unit, with the nomenclature "Tf 318 C" which because of the lower case "f", leads me to conclude that it's designed to trip at 318 degrees, C, or a very healthy 604 degrees, F.
Similar fuses in other appliances range around 230 degrees C (446 degrees F),  which is in the ballpark.
The failure is easy to verify.  If blown, there will be powdery white residue on the inside of the bottom plastic cover near the part.  Also, an ohmeter will show an open circuit across the contacts.  (Unplug the unit before measuring!)
Screws to remove the bottom cover are three tamper resistant torx screws.
If I am unable to find an exact replacement, I will use a thermal fuse in the same power and temperature range (10 Amps, 300 degrees C trip).
Because my unit unequivocably did not experience over temperature conditions, I suspect this is a component aging issue and that there is no other problem with the coffee maker.
Supporting this is the fact that the unit works fine after I moved the good part from my spare coffeemaker to the dead one.
Posted on Apr 13, 2008
Krups FME2 coffee maker won't brew. Flashes an error ---
Most coffee brewers has what is call "resistance" . This resistance get hot to boil the water then brew the coffee and in most cases the resistance get burn and dont brew.
Apr 06, 2015 | Krups Coffee Makers & Espresso Machines
Our Krups heats the water but does not brew
may be its not heating properly try some descaleing
Jul 13, 2014 | Krups ProAroma 453-71 Coffee Maker
Coffee maker won't brew
the pump inside the unit it either clogged or broken
Jul 14, 2012 | Krups Coffee Makers & Espresso Machines
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Jun 20, 2012 | Krups XP Coffee Makers & Espresso Machines
The Krups coffee maker brewed as usual, it was a little hot so I did a few other things went back to the coffee maker it had shut off by it's self and now wont come back on???
unplug the coffee maker. Let the unit cool down for say a half hour. Try another pot of coffee and see if it comes on after plugging it back in of course
Oct 31, 2010 | Krups ProAroma 453-71 Coffee Maker
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
How do i clean my krups proaroma coffee maker
I put a mixture of water and vinegar thru the coffee maker and let it sit for about one hour. Then i rinse clear water thru and its find.
Thanks.
Jun 05, 2009 | Krups ProAroma 453-71 Coffee Maker
Krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Flashing red light
Just found the answer!
The type 453 coffee maker offers a carafe ‘pre-warm’ function.
This feature will heat the carafe for 5-10 minutes before the brewing process begins and is indicated by a flashing red light.
To toggle this feature, push the top-right button in the control panel until the display reads "off".
Aug 08, 2008 | Krups ProAroma 453-71 Coffee Maker
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Krups ProAroma 453-42 Coffee Maker Logo
807 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
