Question about Kicker CVR12 Car Subwoofer
2 12'' cvr kickers
I got 2 cvr Kickers with a kenwood 640 watt amp....for now.
Ive installed systems before so here we go.
I cant get the subs to hit. I tried it on just channel A and I only get tiny bass from 1 sub if both wires are connected. I tried it on channel A and B and same result. The ground is good, the amp turns on, the P.con is connected to remote control on cd deck, Audio cables are connected to amp and deck, Fuses are good, idk what else could be wrong.
It is a 94 mustang gt. It has 2 factory amps in the back and i unplugged them to see if that made a difference and it only stops the factory bass. I have played with the audio cables to make sure i didnt mix them up and im sure everything is hooked up correctly. Is there something else im missing?
thanks, Ben.
  • 185 Answers
Ya u allreadyfound ound out the problem u have factory amps there u go after market
Posted on Apr 09, 2008
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
BP1200.1 Car Audio Amplifier: is that amp good for 2 12 inches subs kickers 600...
that will most definitely be the best amp you will own and the only amp you will ever need to purchase.
May 13, 2010 | JBL BP1200.1 Car Audio Amplifier
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
I have an Audiobahn A8000T amp and 2 12" Kicker CVR (DVC) Dual voice Coil. The Subwoofers are 2OHM a peice. What is the best way to hook this all up to run a 2 OHM load to my subs?
This is a link to Kicker for your CVR12 Subs...if you have the 2 ohm version (2 ohms per voice coil) and you have 2 speakers ....you will need to wire EACH speakers voice coils in series to get 4 ohms from each speaker and then wire the 2 speakers in parallel.....as in....2 ohms in series with 2 ohms = 4 ohms....both speakers wired same way, then in Parallel with each other = 2 ohm load. Page 2 of this link gives examples of both series and parallel wiring of your speaker.
http://www.kicker.com/sites/default/files/2006CompVX.pdf
If you are still not sure as to my description of ' How To',
PLEASE respond and I will attempt to explain it EXACTLY via wiring directions.
Nov 18, 2009 | Kicker CVR12 Car Subwoofer
Sound
Try making sure all wires are of same lenght and guage as well as correctly conected.
Aug 20, 2009 | Car Audio & Video
Bass 2 powerful?
yes will definately blow them you need bigger speakers! im stuck on ma audio subs great wattage for the price ! and shake hard!
Feb 26, 2009 | Car Audio & Video
Kickers dont beat like they should
try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Jan 20, 2009 | Jl Audio 500/1 Car Audio Amplifier
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Subwoofers
sell me the subs it would be better
Oct 29, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker CVR12 Car Subwoofer Logo
148 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
