Question about Microsoft Xbox 360 Console
Original xbox the disk drive has a loose connection that goes into the laser eye how do i put it back on
  • 3,037 Answers
Might need to soder it, I would take it to an electronics store if you are unsure and have them do it, it shouldn't be too hard to do, or cost too much
Posted on Mar 18, 2008
Xbox 360 not working
Open the disc tray and blow inside a couple times real hard to get the dust off of the glass laser eye lens. You can also buy a can of Airduster which will do the same thing. And if you really feel like it, you can remove the cover of the xbox, get a cotton swab, dip it in rubbing alcohol and clean the glass laser eye lens.
If the unit is dirty, this will fix it.
If cleaning doesn't help it, then you probably have a faulty laser lens circuit. This is caused by leaving xbox on it's side and not flat like they we're originaly designed to do . Putting the xbox on it's side and standing it up will ruin your xbox and can cause the red ring of death!
Feb 07, 2010 | Microsoft Xbox 360 Console
OK I am in Iraq right now and my xbox comes on and all but it won't read any disk. It does not give me any kind of error, it just keeps saying open drive, I do then close it and that process just keeps...
This is dvd drive motor issue, it may be because the motor is loosing strength so it cant connect with the magnet, in which case it will need replacing, as the solution above, or it is the magnet its self that has come loose, this needs gluing back on top of the motor, either way your console needs opening.
If you are desperate to play and need a quick fix, turn off your console and lie it flat
turn it on and wait till it says loading
give it a few raps with your knuckles(don't go mad) where the center of the disk will be
keep doing this it will load eventually.
Remember thumbs up if this helps.
Feb 02, 2010 | Microsoft Xbox 360 Console
Original XBOX will not read games or DVDS
original xbox??..
meaning the black one???
or the xbox 360..
if its original xbox, send it for a replacement already
if its 360,
does it say reading and just goes back to open tray??
-check the time and date settings on the console, even the time zone
-check if there is any corrupted file on the hard drive
-try to load a disc without the harddrive,if this works you need to perform system maintainance on the xbox
Jun 27, 2009 | Microsoft Xbox 360 Console
Xbox cant read any disks
The laser in your xbox probably isn't reading it correctly, you should send it in for help.
May 16, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't say disk read error it just goes back to saying open tray what is wrong with it
Dirty laser eye. They sell disc cleaners and the like. WARNING: If you open your Xbox to clean it yourself, you void any warranty.
May 02, 2009 | Microsoft Xbox 360 Console
Xbox keeps freezing up
The old black xboxes had trouble with the aging cd drive. There are only 2 things that can be wrong with it. 1. The IR laser lens has become dirty. This is particularly common in households with smokers, but it is possible with typical use as well. This fix invovles taking the xbox apart, taking the top off of the cd drive and finding what looks like a small contact lense in the middle of the drive. Dip a q-tip in windex or alcohol and then flick it with your finger to remove excess liquid. Then, you can VERY GENTLY wipe across the lense with VERY LITTLE pressure. Wipe across the lens a couple of times and you should be good. If that doesn't fix it, there is a worm gear that moves the laser eye back and forth to read the CD. If that worm gear is not well lubed or dirty enough to be stopped consistantly at the same place it would duplicate yoiur problem exactly. You will want to get electronic gear lube from your local electronic supply dealer. Ask them for white grease. Radio shack will not have this grease. Apply the grease to the worm gear fairly lightly. There is no need to smother it and smothering the gear with grease is likely to just attract more dirt and therefore more problems.  In either case, put the top back on the cd drive before testing it as the laser is an eye hazard.  If you can find a replacement cd drive that might work too. If all else fails take your xbox to gamestop and get some trade-in value for it so you can buy the newer version. Good Luck!!
Feb 27, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont play my 360 games it always says open tray
try to get those pressurized air guns and blow it in there. for a quick check try to blow into the tray lightly. this could be caused by dust build up. Microsoft doesn't cover this so if that don't work open it up and test the connection in the back of the drive to see if it's loose. if its not that. open up the drive and get a q-tip and dip it in alcohol then clean the laser eye with it lighly
Feb 21, 2009 | Microsoft Xbox 360 Console
On my xbox 360 when i have put my fifa 09 it say reading for a while then it says play dvd or clean your disc with a clothe and it really annoying me ?? jack
this is your laser thats losing power and needs either cleaning or the power adjusting so that its optimum again.
dont clean with the common disk cleaners as they are very abrasive and can actually damage the 360 laser eye.
instead strip down the console, then strip down the dvd drive and clean the laser eye with a cotton earbud with a little spit on the end of it. wipe the laser eye with a very gentle clockwise motion.
put everything back together and test if it works then you have done it. if it still does the same then you need to adjust the laser to make the power stronger so it will start reading again.
email me if you need help adjusting the pots on the laser.
ps: this can also happen if the disc is damaged or has the rings around it.
Feb 03, 2009 | Microsoft Xbox 360 Console
Xbox360 that doesn't know it is one
I had the same problem,If it is under warranty send it in ,,, if not then you are going to open it up,, plenty of instruction on how to do this online (google it). see what type of dvd drive you have and then go on ebay and purchase an identical replacment drive. once you recieve it open up YOUR ORIGINAL DVD DRIVE and unplug the green motherboard looking thing on top(Big ONE) there should be four little tabs on this. put it to the side . now open up the new dvd drive and repeat but make sure you dont get these cards switched up.put the old key in the new dvd drive , plug in all 4 tabs,bottom one first. put back together and install back into xbox360. put xbox 360 back together put in disk and enjoy
Sep 29, 2008 | Microsoft Xbox 360 Console
Problem
Did this system play games at one time? If it isnt the original dvd drive with the original bin it will do this. Otherwise you just need to replace the laser or the dvd drive.
Jan 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
