I keep getting error 99 message
Error 99 is common error on Canon cameras. Make sure the battery is freshly charged. Take the battery out, the compact flash card out, and the attached lens off of the camera. Leave the camera set for a while for the capacitors to bleed off. Around a half hour would be good. Next re-insert the battery and push the shutter button as if you were taking a picture. If you get an Error 99 then, you can't fix the trouble and Canon will have to do it. If you do not get an error 99, power the camera off, insert the compact flash card, power the camera back on and press the shutter button again. If you get an Error 99, the trouble is in the compact flash card or its connector. Try a different card. If you do not get an Error 99, power the camera off, a lens on it, power the camera back up, then press the shutter button once again. If you do not see an Error 99, the problem is no longer in the camera. If you do see an Error 99, power the camera off and remove the lens. The problem is probably in the contacts on the camera or the lens. Clean the contacts by holding the camera carefully with the lens opening down so it will not allow dirt to get inside the camera. Take a cotton swab dipped in alcohol and clean the gold metal contacts well, Dry the contacts with a tissue. Next hold the lens with the contacts down and repeat the process on the contacts on the lens. Be very cautious not to allow lint, dust, or alcohol to get into the camera body or into the lens. Some people use a pencil eraser to clean the contacts but you have be very careful not to let particles enter the camera or lens. This should clear your trouble, if the camera passed the first step of troubleshooting.
I was shooting an event tonight, when my CF card got full. I turned off the camera, changed the card and tried to turn it back on but it won't turn on! HELP! I tried it with a fresh, full battery and still nothing, and then it wouldn't turn off!
Same problem here with a 3 month old Rebel XTi. Shot a bunch of pictures, exhausted battery, recharged overnight, re-inserted battery, NO POWER! Had dealer look at camera and he checked battery, lens, manual mode, etc. Said camera was dead and needed to be sent in. Checked this site and replaced the date/time battery and still NO POWER. So much for Canon's reputation! Taking a six week trip without it. . . back to my point and shoot NIKON! Has never failed me in 5+ years!
Same here no power. How do you fix a bent CF pin? or can you?
I have the same problem too. I was going to upload my pictures on my computer but when i went to turn on the camera nothing came on. ( I had not plugged it up yet) I just thought that the battery was dead but when I woke up the next morning and put the battery in nothing still didnt happen!!! And that camera isn't even a month yet!!! :-@
How to you fix a bent cf pin?
