FixYa.com
Tags:
Denon AVR 3808Ci 7.1 Channels Receiver
What is the right rs232 cable to connect a Denon...
posted by EpicZero on Feb 27, 2008
I'm trying to connect my Denon 3808CI Audio/Video Reciever to a Phillips RFX9600 serial extender using an RS232 DB9 male to DB9 Female rs232 cable. Essentially, this allows me to use a universal remote to use RF frequency to control my reciever, a much more reliable way to control my equipment and also allows 2 way communication with my universal remote (so that my remote can display what the volume level is and what radio station is on).
Anyways, I'm not sure what the proper RS232 cable to get/make for this connection is. The RF9600 requires a male DB9 plug, the denon 3808CI requires a Female DB9 plug. The Phillips RFX9600 is really light on details for what type of rs232 cable is needed, but I have read on a forum website called Remotecentral that it only requires pins 2, 3, and 5. As for the Denon 3808, here are the Serial specifications given for that amp:
Connector Specification: RS232C
Connector Type: DB-9 Female type, Slave Straight connection(DCE Type)
(1pin : GRND, 2pin : TxD, 3pn : RxD, 5pin : Common(GND), 4,6,7,8,9pin : NC )
:::Communication Format:::
Synchronous System : Tone Step Synchronication
Communication System : A half duplex
Communication Speed : 9600kps
Character Length : 8 bits
Parity Control : none
Start Bit : 1 bit
Stop Bit : 1 bit
Communication Procedure : Non Procedural
Communication Data Length : 135 Bytes (Maximum)
So if anyone can make sense of all this and could point me to the right cable to get for this connection or what the pinout connections should be if i want to make my own cable (db9 male to db9 female) that would be exteremely helpful. Im fairly confused by most of this rs232 stuff so any help at all would be great.
Thanks,
Eason
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Receivers problems?
Zone 2 problem for AVR 3808
I have outdoor speakers... Answer This...
What is a scart
I have never heard of this term Answer This...
Can not get HDMI video from any...
Connected HDMI from Cable... Answer This...
iPod
I recently purchased a new... Answer This...
Danon 3808 ci Trying to do...
Has anyone put together a... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
