Question about HP Color LaserJet 3500 Printer
How to clean Density Sensor of Hp 3500 ?
Where is the location of density sensor ? I have to clean it because printer gives me density sensor out of range error. Maybe i can solve this problem when clean it.
Any advide will be appreciated.
  • Anonymous Mar 07, 2008
    I have same eror.
Thank you for this info. I used your advice to fix my HP printer and it worked. By the way, great link to HP support parges on the www.partshere.com site. I was able to fix my printer and by the way purchased more printer parts and fusers. Thank you again!
Posted on May 02, 2008
HP Laserjet 3500 prints grey in background
Posted on Jan 16, 2009
    New Friend:
  • 159 Answers
Image halftone control (D-half)
The control is to measure the halftone density sent from the formatter and send the
measurement back to the formatter so that the formatter can perform an ideal halftone
calibration.
The DC controller controls the D-half, following the sequence below, upon receipt of a
command from the formatter.
The following is the sequence of this control.
1. The DC controller forms each color’s density detection patterns on the ITB according to
the image data received from the formatter, at the best developing bias value adjusted
under the D-max control.
www.partshere.com Partshere Troubleshooting
2. The DC controller detects the density of the density detection patterns on the ITB by the
image density detection and sends the data back to the formatter. (See Figure 5-56.
Image density detection, below)
3. The formatter calibrates the halftone based on such data to obtain an ideal halftone
image.
The density of all four colors’ image density detection patterns formed on the ITB is detected
to adjust the image density.
The DC controller controls the color misregistration sensor (PS5) during the foregoing D-max
and D-half controls for this detection. PS5 consists of two detection sensors, which are used
in conjunction with the images on the ITB, each having one light emitter (LED) and one light
receiver (PD).
1. The DC controller sends LED DRIVE signal (REGLED) and lets the LED emit light.
2. The light of the LED is reflected off the density detection patterns on the ITB and
received by the PD on the sensor. The light amount received at the PD differs
depending on the toner density where the light is reflected off.
3. The light receiver converts the received light amount to voltage and sends it to the DC
controller in the form of the IMAGE DENSITY DETECTION signal (REGPDD).
4. The DC controller converts the REGPDD signals to density value (digital) and stores
them.
Figure 5-56. Image density detection
The DC controller notifies the formatter of each error when the following errors are found
during image density detection. The initial value is reset to the new image density
adjustment value when an error occurs.
􀆔 Image density sensor abnormality warning: No light is received at the light receivers.
􀆔 Image density out of guaranteed range warning: The measurement is found to be out of
Posted on Mar 15, 2008
SOURCE:
I had a problem my color laserjet printer 8500dn that is asking to clean density sensor I don't no how to do it please help
Hi Elias, The link below is a user manual for a color laser jet 8500, 8500n, 8500dn, I had a look and the answer to your question (Clean density sensor) is on page 155 (To clean the density sensor
1 Open the upper right door.
2 Use the brush located next to the sensor to remove all toner particles from the sensor)..... This WILL Help...CHEERS..
http://h20566.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00656644
Mar 30, 2016 | Office Equipment & Supplies
E=9 Ricoh FW 780 Black and White Copier
toner density sensor voltage is less than 0.5 volts or more than 4.5 volts.
cLEAN THE
1) Toner density sensor 2) Flow of the developer at the toner density sensor area
Jul 02, 2012 | Ricoh FW 780 Black and White Copier
Where is the density sensor on hp cm1312 colour laserjet?
thank you for your advise. we are having this problem, light black printer, colours are not good. we thought of the laser scanner, but thats above...as opposed to looking down, where toner can fall during print.
Dec 29, 2011 | HP LaserJet CM1312 All-In-One Printer
WHAT IS DENSITY SENSOR IN LASERJET 8500
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
Our Trusty steed HP 8500 has just started to print a thin twin line and other spurious marks on the top side of prints. Today i replaced the drum / fuser / other bits but no difference any ideas?
I have looked at the manual but there are so many possibilites! You can download the manual here and go to page 148 (PRINTING QUALITY PROBLEMS).
Initially I would follow the directions for clearing drum related errors:
Dark or white lines or streaks in all colors, including black.
Print the configuration page five times. The defect should clear
with continued printing. If the defect does not clear, turn the
printer off and on to reset the printer’s density calibration. If the
problem persists, replace the imaging drum. For more
information on replacing the imaging drum, see the installation
guide included with the drum kit.
Then clean the density sensor.
from the sensor.
Note
You can also use a hand wipe to clean the
density sensor. To prevent scratches on
the sensor, do not use any paper products,
such as tissue or paper towels, to clean the
sensor.
3 Close the upper right door.
It could possibly be a problem with the transfer drum.
I am sorry this is not of much help!
Nov 13, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Density sensor out of range
The density sensor is located in what is called the Colour Registration Detection Assy. When you open the front door where the ETB belt is, the assembly sits were the door closes at the top on the printer side.
It can get toner on it, so check it and give it a clean. But do not touch it with your fingers.
Oct 22, 2008 | HP LaserJet 4600dn Color Printer
Hp 3500 faint printing and colours wrong
Rich,
Well, first off, are you using OEM or compatible cartridges? Compatibles are OK, just as long as they weren't rebuilt just by refilling. Secondly, you may want to check in the "Print Quailty" menu; here you will find info on increasing and decreasing the print density. Do you observe light printing over the entire page or just ceratin areas? How about certain colors? More to follow...............
Aug 12, 2008 | HP Color LaserJet 3500 Printer
How to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
particles from the sensor.
Jun 06, 2008 | HP Color LaserJet 8550dn Printer
CLEAN THE DENSITY SENSORS POINTING AT THE TOP OF THE TRANSFER BELT. A COLD RESET CAN HELP TOO
Jan 20, 2008 | HP Color LaserJet 3500 Printer
HP Color LaserJet 3500 Printer Logo
2,425 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
