Back to:
Tags:
PC Laptops
Generic problem for all PC Laptops
Hard Drive (by 2 users)
posted by PSCOLLEN on Feb 27, 2008
I have a Ei System 4419 laptop and it will not find the hard drive
SAME PROBLE ON MY 4419 SWITCHED HDD AND NOW SAYING MEDIA TEST FAILURE AND CHECK CABLES????
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 06, 2008
Good description of what to do on MP/Presario support webstite.
Solution #1
posted on Feb 27, 2008
Not Rated (0)
NetSalem
Rank:Wiz Wiz
Rating: 84%, 30 votes
Most likely your hard drive has crashed. I repaired several laptops with that error and I had to replace a HD and reinstall operating system. Some laptop manufactures will provide a system recovery disk which will help you to reinstall your operating system. Otherwise you will need to install it from scratch. Most likely all your data is lost.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Hard Drive:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
how to upgrade ram?
Toshiba Satellite A135-S2246...
to whom so ever it may concern, i am having a toshiba...
Toshiba Satellite A45-S150 (PSA40U-0F0Q4V)...
another it says cmos not right or battery low.
says cmos not right or battery low what can i do
Compaq Presario 700 (470024-192) PC...
I am using Compaq presario C713TU model and I am...
Loading problems.
Repair Service
Find PC Laptop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
