Question about Car Audio & Video
Volume of my stereo went to maximum.
The stereo of my BMW 530i, 2003 went to maximum volume out of nothing. While driving it just went to max and there is no way to lower the volume. Any idea of what went wrong?
I lowered the bass and balanced everything to right and front seakers to avoid damage, there is no way to bring volume down using the radio of controls on stearing wheel.
    Scholar:
  • 60 Answers
Before you do damage the speakers, locate & remove the fuse/s for the radio. This will at least disable the unit until the problem can be isolated.
Does the 530's owners manual have any info regarding resetting the radio? The unit maybe stuck in a loop or is processing an error & won't respond to external commands. Today's in-dash units are microprocessor controlled & occasionally need to be rebooted, like a windows based PC. Removing the the fuse/s may accomplish this. Wait for about an hour, re-insert the fuse/s & see if the problem is resolved.
If not, have you checked with BMW? There may be a service bulletin covering the wiring in the steering column that might be at fault. Good luck.
Posted on Feb 27, 2008
Radio developed fault. Sudden max audio output which cannot be reduced by volume control.Just before fault, a click was heard in the back of the car.
If you have steering wheel mounted controls then play with the volume switch and see if that drops the volume, if not unplug the steering wheel control harness for the radio an if that makes no difference then the radio is defective.
Feb 08, 2016 | 2003 BMW 5 Series
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
Radio no longer has any volume: Resets suggested dont work. How to pull this sucker apart?
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Jun 03, 2015 | Boston Acoustics Horizon Solo Clock Radio
The avr 70rds only have +5db max volume?whats wrong?
Nothing is wrong. That is how they express the maximum volume. Most listening will be in negative numbers.
Jan 01, 2010 | Harman Kardon AVR 70
Asus p5ld2-vm/alc882 sound issue:
Take a sound-cable, and plug the "headphone-output" into the amplifier of your home stereo, and crank-up the volume on your amp.
Otherwise, double-click the volume-control (beside the Windows clock)
to open the "sound-mixer" application. Crank-up all the sliders to maximum, and see if that makes a difference.
Dec 30, 2009 | ASUS P5LD2-VM Motherboard
Stereo volume goes up itself
Funny huh? Actually, some aftermarket radios like Pioneer have a setting where it senses cabin volume and ups the radio volume itself to overcome cabin noise. I doubt this is your problem and belive the unit is really "mental" and needs repair/replace...
May 07, 2009 | Car Audio & Video
Volume
is easy just disable the AVS opcion en sound opcions
Sep 28, 2008 | Sony PlayStation Portable (PSP) Console
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Car Audio & Video Logo
163 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
