Question about HP LaserJet 1020 Printer
Scattered dots on the left side of page
Every time i print something, the image comes out fine, but there are several scattered random dots all over the page. most of them are on the left side and some are darker and larger than others.
  • 152 Answers
Replace toner cartridge or toner drum
Posted on Feb 28, 2008
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Konica c360
RE[place the transfer belt, open the right door, that shiney belt is the image trans fer belt that has the image on it to be placed on the media (paper) right above it is there a small plastic device in the middle that looks like it could cause your dots it was bad design that little thing prevents paper from riding on the belt
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 04, 2018 | Konica Minolta Office Equipment & Supplies
My ViewSonic PJD6221 Projector shows scattered white dots on the screen
Your dlp chip is going bad and cannot be fixed economically. Several of the mirrors on the chip are hanging up and they won't come back. It will just get worse. My Sharp XR32X is doing the same thing. New projector time.
Jul 07, 2012 | ViewSonic PJD6221 Projector
Hi, I have HP LaserJet 1020 and few days ago three tiny black dots appeared on the left side of the printed pages, just by the border. The borders apper at regular intervals. I found somewhere that it...
dots printed are from the cartridge, you proved that with the change to the old one. If the fuser was faulty, it would repeat the dot 2.5 times down an 8.5 x 11 page
Replace the cartridge and please use HP , remanufactured cartridges fail prematurley and usually wind up costnig more in service and repair/exchanges.
Jan 15, 2011 | HP LaserJet 1020 Printer
Black dots printing on left side of paper
dots are usually always caused by the drum..drums are very easy to replace..(you don't even need a screwdriver)
here's how..
remove the unit that the toner sits into..it's called a process unit..comes out as a whole with the toners...
next open left cover..
remove waste toner bottle. (drum sits right above it!!!
next remove drum by pushing on grey button and pulling drum
out the left side of the printer.
as far as the jam message you might need to replace tray feed tires located up under the machine
Jan 11, 2010 | Kyocera FS-3900DN Laser Printer
It prints three dots on the left side of the page every time.
These dots may be called as "Garbage Valley"
This means ur printer has got lots to print but it was stopped due to certain reason.
I'll ask u to go through ur printer manual & print atleast 5 pages of garbage valley & while u do this, i'll ask u to reinstall ur printer driver.
Hope it works out.
Thanks
Sep 01, 2009 | Brother HL 1440 Laser Printer
Ink dots on right side of paper
Toner cartridge? So this is a laser printer? In that case I suspect it is not new? This sounds like old age on the main image drum, that will probably give the exact same mark on each page, correct?
Apr 15, 2009 | Dell 3000cn Laser Printer
Rimage Everest III printing quality issues
Hi Jay, do you have any idea how many discs have been printed with this Everest Printer?
Your issue sounds like a hardware error, not an issue with the software you are printing from. Most likely the printhead needs to be replaced, or the control board. Printhead replacement costs approx $1200.
- techware dist
Apr 14, 2008 | Rimage Everest Autoprinter Thermal
Problem with phaser
Phaser 2135 Printer: Resolving dirty looking background or gray haze
Description: Tiny speckles of toner scattered all over the page, even in areas of the page that should be blank.
  1. Make sure the media being used is supported by the Phaser 2135 printer.
  2. Inspect imaging drums for any signs of leakage or excess toner that could be falling onto the print as it travels though the printer. Any leaking imaging drums should be replaced.
  3. Verify environmental conditions. See article Dealing with humidity, humidifiers. If the environmental conditions are not within the specified range, the printer should be moved before trying to troubleshoot the cause to the background toner.
  4. Determine if any of the imaging drums were exposed to light for an extended period of time (more than 10 minutes). If so, then Replace the imaging drum. (Xerox is not responsible for any imaging drums that have been damaged by over exposure to light.)
Additional Recommendations:
Background toner may increase, if printing occurs at temperatures towards the higher end of the specified operating temperature range. For this reason, it is recommended that the printer be moved to another area if at all possible.
In addition, very smooth media types such as glossy; allow toner to more easily scatter about the page prior to becoming fused. Try using a less smooth media if at all possible.
Feb 08, 2008 | Xerox Phaser 2135N Laser Printer
HP LaserJet 1020 Printer Logo
111 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
