Technics 5 cd changer sl-pd787
Opens,closes and rotates, but will not play any cd's
  • 2 more comments
  • tazman21 Mar 08, 2008
    I am not getting any CD info on the displayafter cleaning the lens. It is picking up the CD but, after hearing the lens move, nothing happens.
  • scoelho May 29, 2008
    I have a Technics 5 CD disc changer CD player. It worked well for about 10 years and now has suddenly started giving me problems. When I put the CD inside it only senses the CD and starts rotating. I can hear the Lens move but then after a few seconds, it stops. Even the length shows only 0.00 on the display. What could be the problem..? How can I clean the lens..? I know you have mentioned that some Technics Laser lLens are expensive. If I give it for servicing to a local electronics shop, can they repair it....? Many of my friends have told me to junk the system since it is considered old and obsolete.
  • Anonymous Jan 30, 2009
    I took my player in to be looked at. They said a plastic clear piece had fallen out from the optical. They would have to replace the entire laser deck making the whole repair impractical. The set up fee cost me $30.
  • Anonymous Mar 31, 2014
    My technics SL CH 550 cuts out when I play a CD at 50% maximum volume or higher; (-26dB plus). There's no problem playing the tuner at higher volumes, just the CD player?
  • 112 Answers
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
Posted on Feb 29, 2008
  • fluffy cat Mar 10, 2008
    Sounds like you need a new laser pickup. Some technics lasers are expensive. Post your model number and I will check.
  • Musa Balogun May 06, 2013
    Sl-dv280
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Cd tray closes quickly without pressing switch on Technics SL-pd688
There is a small switch under the tray that stops the motor at the end of it's travel, also one when the tray goes back in.
These can have wires broke off or can be stuck or open circuit
Jun 19, 2014 | Technics SL-PD8 5-Disc CD Changer
SL-PD888 rotates disk tray continuously after turn on
The tray is usually detected by an opto interrupter device. When they or the interconnecting circuits fail this is the symptom you will have. It can also be due to the alignment of the tray. This is why all of my CD players are not changers.
Dec 05, 2012 | Technics SL-PD888 5-Disc CD Changer
Technics 5 cd changer Model SL PC11 will pick up
This is a problem with the laser assembly which requires service. The laser assembly needs to be replaced as a whole. It is not easy to replace them, but someone with patience, and a knack for mechanical things can do it.
Nov 27, 2009 | Audio Players & Recorders
I have a technics 5 changer CD player, model# SL-PD687 and when I place a CD in there it no longer plays the CD. It just moves through all 5 CDs and stops without playing them.
You ever get a solution to this, mate?
I have the same freaki'n issue with mine all of a sudden. Suspect the power supply's not delivering enough power to rotate the spindle-motor anymore, cause if I take this motor out and connect it to a 1.5V battery, it runs...
let me know if you've found the solution please on: tobie dot steyn at gmail dot com.
Oct 16, 2009 | Technics SL-PD687 5-Disc CD Changer
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
Open, closes and rotates the cd compartment, endless...
If there's a disk left over inside, It's stuck in the drive hanger, and should be removed else the changer can't put it back in it's right slot. Open the machine and check for any CD's still inside.
If not, could be that the small sensore (to the left of the head assembly (just before the drve (upside down)) is dirty or messed up.
Try cleaning if.
Jan 17, 2009 | Technics SL-PD687 5-Disc CD Changer
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
840 people viewed this question
 Grubhead
Grubhead
