Question about Dell 1710n Laser Printer
Reset page counter
I have a brother HL 4070 CDW printer and the toner is still
fine but it doesn't print due to the page counter. How can I reset it ?
Thanks for help.
Christina
mines a dell 1710n with the same fault
  • Anonymous Jun 13, 2008
    right, unplugging did not work
  • Anonymous Mar 14, 2014
    reset page counter on dell 2330dn
    Master:
  • 377 Answers
Try to unplug your printer and leave it for 1 to 2 hours.
Posted on Feb 27, 2008
How do I reset the counter for the drum unit on a Brother MFC 9840-CDW. It says to replace the drum but the unit is printing flawlessly.
On the TN-155 toner cartridge, a mechanical 'flag gear' that will reset the counter for each individual cartridge when first 'triggered'.
After each page print, the appropriate counters are incremented regardless of toner content (that is why it is still printing 'flawlessly') and after a pre-determined count has been reached, you will get a warning to change the drum as is will then be notionally (not actually) empty.
Before you decide to reset the 'flag gear' on the drum, make sure you are not actually nearing the physical empty state ... it might be a wiser decision to purchase a refill kit which should come with instruction on how to fill and reset the 'flag gear' (this needs some dismantling of the drum cartridge) or buy a compatible or genuine toner drum cartridge.
In any case, Google 'Brother drum flag gear' for more information.
Sep 20, 2011 | Brother MFC-9840CDW Laser Printer
I have a Brother HL 4070 CDW. I have replace the Magenta cartridge but it seems to be spilling ink. When I print in color, the images are not good.
Make sure that the toner cartridges are installed properly.Make sure that the drum unit is installed properly.Make sure that the belt unit is installed properly. Perform the calibration. Adjust the colour by using the custom setting in the driver and by using the control panel. Colours the printer can print and colours you see on a monitor are different. The printer may not be able to reproduce the colours on your monitor. Make sure that you use paper that meets the printer's specifications. Put in a new drum unit.Put in a new belt unit. Check the printer's environment. Conditions such as high humidity and high temperatures may cause this print quality problem.Identify the colour causing the problem and put in a new toner cartridge. If the problem continues, put in a new drum unit. Also visit >>
Image Defect Troubleshooting
Sep 06, 2011 | Brother HL-4070CDW Printer
I HAVE HL 2140 PRINTER. INSTALLED NEW TONER BUT NOT PRINTING GETTING WITH DRUM ERROR
It is possible that the drum needs replacing.
Print a lifetime status page, and see if it says "drum 0%". If so, replace the drum and RESET the counters by using the reset button combination.
Mar 14, 2011 | Brother HL 2140 Laser Printer
Brother hl-2030 - hi, is it possible to know how many pages a drum has printed?
Most laser printer do not have a page counter, because the toner cartridge may come in a couple of toner sizes and there is no way of accurately determine how much tone is used on each page as this can vary considerably.
If the printer gives a message that the toner is low, you can get several more prints by shaking the toner in a horizontal position and placing it back into the printer.
Dec 02, 2010 | Brother HL-2030 Laser Printer
We have a Brother HL 4070 CDW printer and it's leaving black smudges down every printed page. We have tried vacuming it out, but that did not help the smudges. Any ideas?
Hi there !
this is a commun problem for all the printers, you should clean you printer's inside !
for that printer you habe to check all the way where the paper moves.
Aug 20, 2010 | Brother Office Equipment & Supplies
Brother HL-4070 printing out black whole page. Is this drum problem?
Try swapping the black and the magenta (red) cartridge.
This will not damage the printer and you can see if the toner or the drum is defective.
If you get a red page, drum
Black page, toner cartridge
Mar 26, 2010 | Brother HL-4070CDW Printer
I have the Brother HL-4070CDW and I have a TONER LIFE END message and it will not allow me to print anymore. How can I make my printer keep printing until I see visible quality issues?
With the front access door open, press and hold the cancel button. While still holding the down the cancel button, press and hold the reprint button... you should now see the toner reset menu. Why we can't get there from the machine info/reset menu to begin with, well, guess Brother wants to sell you more toner. ;^)
Dec 07, 2009 | Brother HL-4070CDW Printer
What is a waste toner box. what does it do and
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Oct 10, 2009 | Brother HL-4070CDW Printer
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
Dell 1710n Laser Printer Logo
309 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
