Question about Minolta bizhub 200 All-In-One Printer
Bizhub 200 fault code c1183
Code c1183
  • eggor Feb 27, 2008
    can i fix it or do i have to call a repair man
  • Anonymous Jun 12, 2008
    c1183 bizhub error
    Problem Solver:
  • 6 Answers
Its an elevator ascent/descent motor failure. You didnt by any chance have any thing such as a big box of paper or a trash can sitting under the exit trays did you? Check it to make sure the trays are level also.
Posted on Aug 24, 2008
  • paulliam Mar 17, 2011
    THIS FIXED IT. I slid the finiisher out, and gently played with the tray that did not seem level. I slid the finisher back into the machine, and it lowered itself down and worked like new. Thanks.
2 Suggested Answers
SOURCE: bizhub 250 c1183 fault code
I had a similiar problem with a Bizhub C-353. I tried opening closing the front door several time & power cycling galore. Turns out a had a loose on the saddle tray sensor. I wish the stupid thing would have just said "Finisher tray full" or something close to it.
efiRules
Posted on Jul 28, 2008
How to solve error code C2351 in konica minolta bizhub 164
On a bizhub 165 it's a fault with the sucktion fan motor so check
to see if turning and replace if needed. If this does not fix print control board might need replacing.
Jul 03, 2014 | Minolta bizhub 200 All-In-One Printer
Bizhub 222 how to open elevator section
Check the exit sensor on the elevator tray (paper exit unit).
Jan 01, 2013 | Konica Minolta Bizhub 222 Black and White...
Bizhub 423 c1183 error code
id someone leave a trash can or boxes under the output trays? To solve this problem requires removal of the rear cover of the finisher. Then remove the elevation drive motor assemble. Be careful don't want the output trays to fall!!!!!! Then while placing them in their proper position re seat the drive assy. The top tray should be just below the orange rollers (If they are cleaned) you will see several actuators the trays has to just touch them.
Oct 10, 2012 | Minolta bizhub 200 All-In-One Printer
C1183 error and service is closed today
check if all trays are fitted in place (open/close them). then power off/on
Sep 18, 2011 | Minolta bizhub 200 All-In-One Printer
Hi please can you help me to resolve my problem with a bizhub 35 it's get me a code number c1183
Hi elfethi,
This code c1183 is commonly caused by trays in your finisher which are not fully inserted into it's slot. It indicates an elevator motor Ascent/Descent Failure. You may want to try follow these steps that help you address the concern:
1. Check the output bin trays which are at the far left side of your machine.
2. Make sure that they are properly installed into the holders.
3. Then refresh your system by turning it off and on.
4.After doing these, the error should be gone.
If you're still getting the error after making sure that trays are properly installed then this means that the issue is already with the sensors or elevator motor. You will need to contact a local repair man.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
BIZHUB 350 C1183 MALFUNCTION
Hi richard_hutc,
It would appear that you have an issue with the finisher/sorter on the side of the machine.
Specifically, C-1183 means the elevator motor hasn't ascended or descended correctly.
Open and close the finisher and look for any paper jams in this area.
Good luck
Jan 22, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 erro code c1183
C1183
Elevator motor ascent/
descent drive failure
• The elevator tray lower limit sensor (PC13) is not turned ON
even after the set period of time has elapsed after the main
power switch is set to ON.
• The elevator tray home position sensor (PC11) and elevator
top face detection sensor (PC12) are not turned ON even
after the set period of time has elapsed after the elevator
motor (M11) is energized.
• The elevator tray does not stop at the position for the specified
tray after the elevator motor (M11) is energized (beginning of
descent operation) and the elevator tray lower limit sensor
(PC13) is turned ON.
• The elevator top face detection sensor (PC12) is not turned
ON even after the set period of time has elapsed after the elevator
motor (M11) is energized (beginning of ascent operation)
when paper is being fed out.
May 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
BIZHUB 350 THROWING CODES C1183 AND NOW SHOWS C5351
C1183 Finishing option elevator drive
malfunction
See FS-514 Service Manual.
See P.65
Mar 31, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
Minolta bizhub 200 All-In-One Printer Logo
1,252 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
