Question about LG WM-1090FHB Front Load Washer
Door lock I have taken the door of my lg wm-1095 but cant get at the lock on the dorr, how do i open the plastic rim to get at the lock on the door
    Genius:
  • 1,554 Answers
If you cannot get to it by just reaching between the rubber rim.
The official way is to take off the top and bottom access panels , 3 screws on each in top rear and on the bottom front, then remove the front control switch panel.
then you can remove the front of the machine.
Posted on Feb 27, 2008
Door wont open
Late answer, but --- unplug the machine, wait for the door switch to cool. Not more than four or five minutes, it should open.
The door switch should be replaced, it's easy to do.
Apr 23, 2014 | LG WM-3677HW Front Load Washer / Dryer
1994 Toyota Camry outer door mechanism jammed
Just cut a square hole in said plastic sheet and look to see what you want to see. Then just tale the plastic sheet back up when your done.
Jun 25, 2017 | 1994 Toyota Camry
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
Hi my LG WD-14311RD washing machine refuses to unlock. Cannot open the door,just remains locked.
My model no is LG WD-14331 AD the door just remains locked cant open i think the handle inside plastic hv broken how to solve can u send some one come to repair or .
BR Chow
Jul 29, 2011 | LG WD14311RD Front Load Washer / Dryer
Hi..am using frontload lg washer since past 2yrs...the door seems to get jammed..am able to open the door only if i try harder..reason?
replace the door lock assembly and this would solve your door issue as these age the inner clip on the door assembly starts to deteriorate with use of opening and closeing the door it is mainly made up of small plastic pieces if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future thanks Rick
Apr 22, 2011 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Lg intellowasher model wm 1290fhb door will not open. tried waiting 1 hour! tried power on and off, tried child lock
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
  3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
  4. The washer powers off and unlock the door.
Oct 18, 2009 | LG WM-1290FHB Front Load Washer
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Door locked
to all of you who have your door locked, i have had that same problem and my husband found out how to open it. under the bleach and softner dispenser there is a light green plastic chord. pull on that and it will open your door.
May 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
LG WM-1090FHB Front Load Washer Logo
125 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
