Question about Panasonic CT-2784VY 27" TV
Color distortion my television is experiencing some color distortion. What can I do?
color distortion - 7a50932.jpg Panasonic CT 276W1
Posted on Mar 10, 2008
    Master:
  • 377 Answers
Check your TV signal it may cause for not viewing the picture well.
Posted on Feb 27, 2008
2 Suggested Answers
barbu51
  • 566 Answers
SOURCE: RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Posted on Nov 01, 2009
Picture but no sound
If the TV has picture, and only sound is absent, check its speaker first. There is nothing fault with its EEPROM. The fault should be either to its speaker/s or audio output section circuit. Contact any service technician. Gopakumar Gopalan Google
Feb 26, 2014 | Panasonic PT-44LCX65 Television
Distorted Picture
Could you explain a bit more clearly by what you mean by "shifted"? A pic here would help..
Jun 27, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Picture is fuzzy and colors are distorted
You will probably need to replace ALL of the CRT's and do a Full Convergence Alignment by a very experienced tech. Never replace only CRT as it will be brighter than the other two CRT's.
Apr 08, 2010 | Samsung HC-P4752W 47" Rear Projection...
47''REAR PROJECTION PICTURE PROBLEM PANOSONIC
Hi,If you are experiencing color distortion,pixilation,white dots,vertical or horizontal lines it might be time to replace the DMD board. Digital Micromirror Device (DMD), This is how it works: http://electronics.howstuffworks.com/dlp1.htm
Mar 30, 2010 | Televison & Video
The color is distorted and the picture blinks. I've replaced the lamp twice before and i don't think this is a lamp problem.
color distortion (bleeding colors, or overwhelming of one color)on these tv's is commonly the optical engine. that might make it unecinomical to repair
Mar 27, 2010 | Toshiba 52HM95 52" HDTV Projection...
Distorted picture. changes from color to black and white.
Hi, this is a bad main board that is causing this issue you are experiencing. simply replacing this board will fix this issue.
Click Here
May 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
May 18, 2009 | RCA Televison & Video
Humming from back of tv, color distortion
sounds like the color wheel. Do you have a DLP TV?
Apr 22, 2009 | Televison & Video
I have a Phillips projection TV Model# 60PP9202 Chassis # DPTV305F with a linear distortion problem. The colors are not aligning. Can I fix my TV myself, or do I have to take it in. Any advice would be...
It soundsa like you have a convergence problem. Probably only one color. (The green and red may be ok but the blue is bowed or any of those combinations) This will require the repklacement of convergence IC's and then alignment. Probably best to have a experienced tech take care of this.
Nov 26, 2008 | Philips 60PP9202 60" Rear Projection...
Color distortion and arched picture
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Panasonic CT-2784VY 27" TV Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
