Problem with Brother HL2070
All LEDs are on continuously, never off whenever I start my printer HL2070.
Please help me
  • midwestloads Nov 26, 2008
    paper light keep flashing
    Problem Solver:
  • 5 Answers
My red light flashing problem on myHL-2040 was caused bythe plastic horizontal rod out of alignment in the back ofthe printer. Steps: 1. Open the back cover. 2. Gently pull the tab toward toopen the Rear Chute Cover (plasticflap) inside (page 78 of User's Manual). 3. Look closely at the bottom rod ofthe Rear Chute Cover tomake sure everything is aligned. The two"tabs"(one long and one very short) on this rod should fit right into theallocatedslots. 4. If not, adjust the rod so theright end extension of therod will block the paper sensor when the chute coveris pushed in by the backcover. Hope this helps - I wasted hourstrying to fix this problem.
Posted on Oct 16, 2010
First of all, the 2070N is a laser printer meaning it has no ink. Second, we've had the same problem even after replacing both toner and drum. I'm still searching for a fix.
Posted on Mar 27, 2008
    Master:
  • 377 Answers
Maybe your ink is low. That's why it's flashes to give signal for the user that the printer level is low.
Enjoy
Posted on Feb 27, 2008
I changed the new drum for my HL-2040 printer. But the LED light shown orange. Can I know how I going to do reset for the new drum. Thanks!
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000300/000055/faq000355_007.html?reg=eu&c=eu_ot&lang=en&prod=hl2040_all
May 05, 2011 | Brother HL-2040 Laser Printer
I have a problem that a printer brother 2170w wereve the leds error and drum are blinks. please i need help
To reset the drum message:
Open the front door
Press and hold down the white button for about 4 seconds.
Once all 4 LEDs are lit, release the button.
Make sure that the Drum LED is now off.
Feb 11, 2011 | Brother HL-2170W Laser Printer
My Printer Brother Type HL-5250DN.. All 4 led is flashing.. allready take out and put in back toner.. still not working yet.. 4 light still flashing. Need help soon.. Thanks
If all the LEDs then try to turn off the power switch, wait a few seconds, and then turn it back on. If all the LEDs are still blinking, press Go and Job Cancel buttons together and let me know what LEDs stay on.
Nov 16, 2010 | Brother HL 5250DN Laser Printer
1720DN
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
Ink usage problems
from service manual:
To perform a NVRAM init
1 Turn the printer off.
2 Press and hold the GO button.
3 Turn the printer on and continue to hold the GO button.
4 After the Go, Ready, and Attention LEDs turn on, continue holding for at least 20 seconds.
During this process, the Attention, Ready, and Go LEDs will each turn off.
5 Release the GO button.
6 The device LEDs will begin cycling from front to back. The NVRAM-init process runs until the
printer is in the Ready state.
Jul 13, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
How to convert a Brother brand printer with a continuous ink?
Yes your idea of using a Continuous ink system is good and its really much cheaper compare to using the ink from brother, there is many people that are using that ink system and its working fine...
Dec 28, 2008 | Brother DCP-350C InkJet Printer
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Reset the drum counter only when you replaced the drum unit with a new one.
Dec 05, 2008 | Brother HL-2070N Laser Printer
KB? Pitch?
maybe your printer stuck,try to move him manually and then start typewritter
May 07, 2008 | Brother EM-530 Typewriter
517 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
