Leaving the door open on a front loader is not only a great idea, it is recommended by the manufacturer. This not only allows the tub to air out, it also minimizes mold and mildew from forming, However, if you are beginning to experience a musty odor, the following link can give you some suggestions on things to do to keep the washer running odor free:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
The most commmon cause(s) are small articles of clothing get trapped in the folds of the door bellow. Its a good idea to routinely check this area after each wash load. Socks are notorious for ending up in the door bellow and beginning to mildew.
Another common cause is debris in the drain pump reservoir beginning to sour. It may be a good idea to check the drain pump to make sure there's nothing lodged in it. The following link explains how to check the pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
I personally own a front loader and have never had a problem with odors or mildew in the 9 years I've had it by following this regiment.
As far as the bellow is concerned. Some discoloration can be caused by the water you have. In particular if the water contains iron. Some of these stains may or may not come off. You can try using a 50/50 mix of bleach and water in a spray bottle to spray the bellow. Allow it sit for a few minutes, then srub with a green kitchen scouring pad. DO NOT use steel wool, sandpaper, emery paper, or SOS pads. They can damage the rubber. The green scouring pads are considered safe, but abrasive enough for cleaning.
Read through the links provided and let me know if you have any questions. I hope this helps you.
