Question about Toshiba Satellite A45-S150 Notebook
Keyboard problem When I hit some of the keys the will input 2 leys infor like... k is "ik" just as i is "ik" and o and l gives me "ol" and several other keys do the same thing the keyboard it self is only about a year old.
    Master:
  • 474 Answers
Most likely the ribon that attaches to the board is damaged or not seated in straight. also, try updating your chipset/ mainboard drivers also, is could be a software issue. Go to the Manufacturers website and look up any new drivers or r-install the old ones.
also, it may just need to be cleaned out.
Posted on Feb 29, 2008
    Sergeant:
  • 324 Answers
Good morning!
First thing to do is to figure out if this is a keyboard problem or not. Plug an external keyboard in and try it. if the problem goes away, you've probably got a keyboard problem. If it doesn't, you probably got a motherboard problem. If the external keyboard doesn't make a difference, there is not too much that you can do and you are probably looking at a motherboard replacement.
Once established that you have a keyboard problem, take the keyboard off of the notebook and clean it real good. Using compressed air, a brush and firmly tapping it on it's side while using these.
Check the cable and connectors on the keyboard to make sure they are properly seated and not damaged. Plug it back in and try it. If it works, good for you! You've just fixed it. If not, don't mess with it. Get a replacement and you are good to go.
IRon-
Posted on Feb 28, 2008
  • 133 Answers
Its normally a tiresomejob to try and fix a keyboard, try to check if there are ANY stack keys else you need to open the keyboard and clean it.
My @ symbol is stuck on the " sign. I do not have an ALT GRA key. I have an ALT CAR key and and ALT key but neither seems to help. I've tried hitting the Fn key and 2 at the same time but still no...
Sounds like your keyboard in in UK mode, but is labeled for US. Or the other way.
In a UK keyboard, Shift+' (the key which is two spaces to the right of "L") should give you an @ sign.
Depending on your Operating System, you can use the CONTROL PANEL and REGIONAL SETTINGS to set the keyboard to be a USA keyboard, and then Shift+2 will give you an @ sign.
http://en.wikipedia.org/wiki/Keyboard_layout is a good reference for keyboard layouts.
Apr 17, 2011 | Toshiba 310CDT Keyboard
Instead of getting the @ symbol when I press shift +2 i get "
you need to hold down ctrl and function on the left side of your keyboard, and then hit the shift key on the right side of your keyboard. Then let go of right shift while still holding down the control and function keys, and then hit right shift again.
these blue keys are french keys. if you change your keyboard settings to english US or UK, it will get rid of the blue functions, but for some reason, they tend to turn themslves back on again after time. Most likely due to automatic updates followed by an auto restart. Also, I find that the issue only arises if I am in my hotmail account.....no issue in Word docs.
Jan 13, 2010 | HP D8597A Keyboard
If the keys are coded to the1998jimmy computer can we by pass it a used colum was put in with a different key
ok they are a wire that runs al that sec junk i it runs to the switch its self if u have ols ket all u have to do is splice into that wire wrap it around old key and tape it real good so it wont come loose that the way i done my chevy just put old ley under dash somwhere
Oct 06, 2009 | 1998 GMC Jimmy
My keyboard has several keys that have little green charactors on them. For example the u has a 4 and the "i" has a 5 and the "p" has an * I have hit something that turned this feature on and now i can't...
You can put your keyboard in "Numlock" mode if you have a lot of numeric data to input and use these keys for numbers rather than the normal letters. The key sequence varies by manufacturer but it's typically going to be labelled with a rectangle around text such as "NUM LK" and is activated by holding in the FN key and then pressing the labelled key. Deactivation is the same.
As you've found out the hard way, it can be really confusing when this happens accidentally.
Jul 16, 2009 | Acer NSK8458AN Keyboard
A key (which one?) changes the letters all keys type
You're hitting SHIFT and CTRL -- which changes the keyboard input method, i.e., for French keyboard, or for DVORAK keyboard, or for Scandinavian keyboard.
Access CONTROL PANEL, and use REGIONAL settings to "uninstall" all keyboard-layouts that you _never_ use.
Jul 01, 2009 | Microsoft Natural Ergonomic 4000
Need installation software for my ik-0626rp wireless combo
are you install the drivers mouse and keyboard properly.
if not install then please install the driver first to solve this problem.
if you have not the driver then tell me.
i can provide the driver link.
thanks
you can further help me
Apr 07, 2009 | DPI ITSG Wireless Desktop IK-0626RP...
Driver EZKey EZ-8000 Smart Office Keyboard - PS/2 +CD en Manual.
Go to http://www.ezkey.com.tw/support/driverdownload/download_list.php?i=97
Apr 02, 2009 | EzKey EZ-8000 Smart Office Keyboard
KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Jun 23, 2008 | LinxCel PS-121D 2 Port PS2 KVM Switch
Some keys give a different symbol
I have the same problem with Microsoft in both wireless and plug-in.
platypus
Oct 30, 2007 | Logitech Deluxe Access Keyboard
Toshiba Satellite A45-S150 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
