Moving object in turbo c
I have tried it. i used kbhit and getch() function for this. object is moving but on all keys i want it only on arrow keys, and one more thing when i realease the key object gets dessapear. can i get the code for this.
  • 655 Answers
Yaa you can make a check like following:
Lets suppose your up key has a scan code of 28
then you should use
while ((upkey = getch()) == 28)
............do your work to move your object
..............make your object disapear here
Note: m not sure the up key scan code is actually 28
you can chek it after using printf(%d, getch())
Thanks
Iqbal
Posted on Mar 15, 2008
On my new asus laptop I cant use the touchpad to do anything. It seems to have locked. The cursor is on screen but doesnt move.
Sometimes there's a mouse pic on one of your function keys to local/unlock pad. Hold the function key while tapping the f key once to unlock
Sep 11, 2016 | ASUS Computers & Internet
My left click button is not functioning and I can't figure out how to highlight text without it...
You have to use Tab and Arrow key to highlight object,But for text
Shift + Left Arrow will take you to the right alphabet.
Shift + Right Arrow will take you to the left alphabet.
Shift + Ctrl + Left Arrow will take you to the right word.
Shift + Right Arrow will take you to the left word.
Hope will be little helpful to you.
But I suggest you to get an external USB mouse.
Jan 02, 2010 | ASUS Eee PC 900 Notebook
SAME PROBLEM THE ADVICE DIDN"T WORK
Manual say to -
1. Press the “Menu” key on the panel, “Menu” will appear on the screen.
2. Press [arrow left] or [arrow right] key, move the cursor to “image function”.
3. Press [↑↓] key; enter “Display model” function choice.
4. Press [↑] or [↓] key, move the cursor to “Image Revolve”.
5. Press [arrow left] or [arrow right] key to adjust “Image Revolve”.
6. Press [↑] to go back to the Menu.
7. Press “menu” key to exit the “menu” window
If your projector will not do this, the functionality may not be there.
Dec 18, 2009 | Televison & Video
Integral of sinx how to calculte in casio fx991 es
Configure the calculator to be in MathIO : [SHIFT][MODE][1:MathIO].
Press the Integral key, the one judt beloe the [ALPHA] key.
The template of the integral appears, with the cursor in larger rectangle. Enter the function the screen displays the integral, a small upper sqaure, and a small lower square. The left parenthesis of the function is already supplied by the calculator.
Press [ALPHA] X to enter the argument of the function.
Press the right parenthesis.
Remain the limits.
Use left arrow to move the cursor just before the s of sin and press down arrow to enter a numerical value for the lower limit.
Press the up arrow to move cursor in upper square.
Key in the numerical value of the upper limit.
Press [=].
Warning. To have meaningful result, make sure the angle unit used is conform to the problem you are trying to solve.
Hope it helps.
Nov 01, 2009 | Casio FX-300MS Calculator
How do you find the zeros of a function on a TInspire
Turn calculator. Use arrow to highlight the 2:Graph and Geometry application. Enter your function at the bottom of the screen. Use TAB to move focus on command line.
Press [ENTER] to graph.
While graph is drawn, press [menu] key. Select [5:Trace][1:Graph Trace] . An X appears on the graph screen. Use arrow to move cursor towards one of the zeros you see. At some point the calculator will pop up the label [zero]
Press [ENTER]
Use arrows to move the cursor near a second zero. When [zero] pop up text appears, press [ENTER]
The value of the secon zero is also displayed.
You can also the nSolve command
Use the nSolve( function available in main calculator application. Here some exemples of syntax
On the second command line, the small vertical segment after the right parenthesis is accessed by the key sequence [CTRL] [infinity, beta, degree] key, the one under [left arrow/clear].
Hope it helps.
Oct 26, 2009 | Texas Instruments TI-Nspire Graphic...
When in a spreadsheet, the arrow keys do not move cursor
first try to see the cursor is not within the cell blinking cause sometimes when the cursor is within the cell it traps the controls and will not able to function on your desire output. so try to observed it again.
Jun 16, 2009 | Microsoft Excel for PC
Arrow keys do not function in bios
Arrow keys move the cursor into fields + or - keys change the values of the fields.
Sep 23, 2008 | Dell Latitude D600 Notebook
C programming coading
3 3 3
4 4 4 4
5 5 5 5 5
Apr 30, 2008 | Computers & Internet
Font size
If you continue to have problems changing the size, make sure the 'bent arrow' next to the BS key is not on. Once I took that off I was able to make the need adjustments to my size and style.
Feb 13, 2008 | Brother P-Touch 1180 Label Printer
Computers & Internet Logo
416 people viewed this question
Alun Cox
David Payne
David Payne
