Back to:
Tags:
Vanguard International Infra Red - Large Infra-Red Baseboard Heater
We have a model VP1600E Propane Space Heater
posted by jgjjdj on Feb 27, 2008
The Pilot Flame Looks Yellow And High The Heater Clicks After It Has Been On A Few Minutes And Cuts Off What Can I Do To Repair It?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 11, 2008
Helpful (85)
soleman13au
Rank:Wiz Wiz
Rating: 88%, 35 votes
Not sure I can help but will try. Sounds like you have a blockage in the pipe or jet and when it heats up it is choking. Best way to clean Propane and/or Gas heaters is to blow compressed air through the pipe. You may be able to just blow the air down the pilot light and main jet and it could fix the problem and clear the jet.
If not you will need to pull off the covers to expose the piping and look for the pipe going to the jet or pilot and if you can undo the pipe and blow compressed air through it. You may find a bit of dirt or carbon is causing the blockage. If you undo any pipes make sure you tighten them back up. Hope this solves your problem.
regards
Bryan
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on We have a model VP1600E Propane Space Heater:
I don't want to Accept this solution
Can you Help with these Heaters problems?
Heaters
Recently changed the Mode Button on the Brivis Networker...
Heaters
I've only use this a couple of times and tried to lite it...
Heaters
pilot light goes out after furnace starts up coleman...
Heaters
The igniter turns bright orange and the gas ignites but it...
Heaters
The unit comes on for about 2-3 seconds and the ignitor...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
