Look across the top row of keys you should see a round sort of sun symbol with nothing inside, along side that another one the same, but filled in, or something like this, theses or the like are used with the Fn Key to brighten & darken the display
If the picture mode is set to Cinema or Custom, the screen could become dark. If the screen is still dark after the picture quality mode has been changed, change the setting Backlight, Picture, Brightness and adjust the brightness to your taste. ... Depending on such settings, the picture brightness level can be higher or lower
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1
Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2
Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3
Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4
Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5
Click "Change Advanced Power Settings."
Step 6
Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7
Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8
Click "Plugged In" and set its brightness percentage.
Step 9
Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10
Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks,
Anand
Well reguraly you use funtion key (Fn)+ a key with a sun full for more bright and a sun empty for bright . Remenber press Fn and then the other repeatly.
You can't change the brightness of the top screen but you can change the brightness of the bottom screen to match/ suit your needs.
Whilst the DS lite is off tke out any games that may be in it, Turn the unit on and touch the screen to take you to the main menu screen. at the bottom left of the menu screen you will see a little sun picture... tap that to change the brightness of the bottom screen, there are 4 stages of brightness to choose from.
Hope this hels, any further questions please feel free to contct me via my profile page.
Follow the 2 steps I follow all the time, retry, and restore your ipod. My itouch's screen was also really dim but when i restored it, it turned bright.
