Question about Motorola Mobility RAZR V3m Cellular Phone
Can not connect to my blue tooth
When I try to connect another person name comes up on my phone. I go in to rename to my name and it still shows this person name. when you check the status it shows the phone is disconnected. please help
    Brigadier General:
  • 7,752 Answers
Do a master reset and master clear of your phone then retry it
Posted on Mar 19, 2008
How do I connect a blue tooth device that is already paired in my Samsung intensity 2?
Disconnect it first. means power off. unpair the device restart devices pair it again.
Oct 11, 2017 | Samsung Intensity II SCH-U460 Grey Verizon...
Rename C hard drive correctly.
First,you didn't post the Make, model of laptop or the OS you are using? Second have you unplugged and removed the battery in the Laptop, plugged in, rebooted? Can you enter BIOS setup? At boot try a System Restore/Recovery.
Mar 02, 2013 | Computers & Internet
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
Pairing to nokia 6700
both party A and B blue tooth should be on
from nokia 6700. go to settings , connectivity , blue tooth open . turn on blue tooth . and scan .. click on the party B ( buddy phone ) confirm the name from the other person whom u want to pair and then sent a req ( it ll be asking for pin. use any pin of your choice i.e 123 and the party B ll be prompt for a pairing n enter pin. he must enter the same pin u have put in on your phone before sending a req, it ll be done
Feb 21, 2010 | Nokia 6300 Cellular Phone
Motorola Bluetooth Won't connect
hello there! there are actually several cell phone brands that don't have any easy access if opening the blue tooth..one of its main reason is that some phones are just reconditions. in your case, try consulting the nearest center wherein you had purchased your phone and inquire on how you can on your bluetooth. it happened to me already with my nokia recon phone, i can't work my blue tooth myself so i tried asking the assistance of a nearest gadget center and poof! they solve it right away. for more inquiry, please keep in touch with me. thanks!
Apr 10, 2009 | LG Shine CU720 Cellular Phone
Please Answer
Bluetooth, when activated on your mobile device, you get to chose to be noticed or not. If you chose NOT, then anyone with bluetooth seeking to connect with another device with bluetooth, you're device WILL NOT come up. It'll only show up when you chose YES to notice. When someone is seeking via bluetooth for another bluetooth device to connect with, they'll find your's. You'll have a personalized name or a generic name. Typically, the generic name will be the model of phone you are using. Plus, bluetooth can only connect to one thing at a time. Can't do multiple pairings. In some countries, young adults leave their bluetooths open and noticed for all to find as a dating network.
Hope that answered your question!!
Cheers!
Feb 04, 2009 | LG Prada KE850 Cellular Phone
Conecting blue tooth
You did describe the full question.
If you have facing some problem while connecting via blue tooth check you these sittings
you phone have name in blue tooth
your phone should be visible on
And you should one it while connecting to any device then you can search for any blue tooth device.
Let me know if you have any other question regarding this topic.
Nov 18, 2008 | Cell Phones
Motoq internet does not open page
FREE INTERNET FOR YOUR MOTO Q
You need a blue tooth doggle 30 bucks at wallmart
install usb blue tooth doggle on ur pc or notebook
on your phone goto bluetooth folder. connect to personal network
open up active sync on phone and click menu then connect via bluetooth.
Try browsing the web. Your online and its shared from your home connection.
Feb 14, 2008 | Motorola Mobility Moto Q
Motorola Mobility RAZR V3m Cellular Phone Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
