Try booting the system to Safe mode.
To boot to safe mode:
Restart
the computer. As soon as the BIOS has finished loading, F8 key on your
keyboard. When Windows Options menu appears, scroll to select the Safe
mode menu item, and then press Enter.
Select "Last known good configuration" then press Enter.
If that doesn't work reboot again and keep tapping on F8 to Safe Mode and instead of selecting "last known good configuration" select "Repair Your Computer"
Or you can try this:
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
- Place
your Windows XP set up disk in your CD drive.
- Turn
off your computer and change your BOOT order to boot from CDs first.
- Turn
your computer back on.
- Press
any key on your keyboard when it asks you to.
- Press
enter when you see a blue screen, one of the options should say, "To
setup Windows XP now, press ENTER.".
- Press
enter to start the windows set up.
- Accept
the Licence and Agreement and confirm that the setup is searching for
current versions on XP.
- Press
"R" when the set up has found your current version of XP.
- Notice
that the Set up is deleting all your windows xp files and replacing them.
(This will not cause loss of data)
It just stops at system is starting pressing enter doesn't work either
