Power amp one side went out protrction stays on
  • 38 Answers
Protection comes on when DC voltage is present on centre rail. Replace defective components to resolove this issue. Protection prevents DC travelling through speakers and destroying them.
Posted on Mar 03, 2008
2006 Peugeot 2.7 HDI.Gearbox-protrction mode-NRPD faulty, depolution system faulty,air suspension faulty, automatic headlamp adjustment faulty. What could the problem be?
I hate to say it, welcome to French car electrics. Check as many harness connections as you can for fit and corrosion. Especially the fuse box plugs.
Feb 12, 2017 | Peugeot Cars & Trucks
Turn signal wont flash, hazzard lights and turn signal just stay on, left side started blinking fast, then went back to normal, now they just stay on.
it may be the flasher unit is faulty & needs to be replaced, you should find it under the dash on the drivers side it could be a square or round unit with a connector plug on it, when you remove the connector plug the unit has three pins on it........hope this helps.......cheers.
Sep 23, 2011 | 2003 Ford Expedition
The battery went dead, had to jump start the car. The radio stays off & a blank screen. how do I restart the radio Thanks
GET A GOOD FUSE TESTER, TEST EACH FUSE. THERE ARE 2 FUSEBOXES. ONE UNDER THE HOOD & ONE IN THE DASH. ALL FUSES CAN BE TESTED WHILE STILL IN PLACE. THERE ARE TEST POINTS FACING OUT. TURN ON IGNITION SWITCH FOR THIS TEST. POWER ON 1 SIDE, BAD FUSE POWER ON BOTH SIDES, GOOD FUSE. POWER ON NEITHER SIDE, SPARE FUSE.
Jan 10, 2011 | 1991 Lexus LS 400
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
Nov 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Component speaker not working
The easiest thing to test is to try swapping the connections of the front component speakers at the amp connections. If the problem follows the speakers, the issue is probably with the speakers. I would triple check (again) the speaker wire connections. It's also possible the crossover for the driver side component speakers has an issue (thus why the tweeter worked for a while).
If the problem stays on the drivers side, the issue is probably with that channel on the amp. Triple check the RCA connections for that channel.
It's much easier to test other speakers on an amp channel versus trying to check it with a meter.
If the driver's door is "abused" often, my initial thought is the wiring at the speaker or the wiring in the speaker (to voice coil, within the crossover, etc) is the most likely culprit.
Apr 10, 2008 | Infinity 475A Car Audio Amplifier
Onkyo SR502 Shuts off by itself
It is not a blown fuse. Your baby is in its ***** throes! It is fubar. You have either a damaged power supply or blown output stages (since sounds horrible it is probably this).
Sep 17, 2017 | Onkyo TX-SR502 Receiver
63 people viewed this question
 Grubhead
Grubhead
