Question about Dell Precision 360 PC Desktop
Is my system board or the processor damaged?
I could see that there a beepy blinking led on my system board but the system fan is not working at all neither does the system boot.
    Sergeant:
    Champion:
  • 317 Answers
Sounds like you have a bad motherboard, my only suggestion is to call dell, and see if they can get you a replacement one.
Posted on Feb 27, 2008
If a warning light indicates the CPU is not functioning, does that mean I have to get a new processor?
Yes! judging by all the cascade break downs, I would suggest replacing the motherboard, HP has a history with motherboard issues.
Mar 29, 2012 | HP Computers & Internet
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
My d530 minitower powers off unexpectedly and red lights starts to blink on System's LED//
Hi Kindly let me know how many times the red light blinks
Condition Code Service Actions Processor thermal protection activated. Power LED blinks red twice, once a second, followed by a two second pause.
  1. Make sure the computer air vents are not blocked and that the cooling fan is running.
  2. Open the hood, press the power button, and see if the processor fan spins. If the fan is not spinning, make sure the fan cable is plugged into the cable header on the system board, and that the fan is properly installed and seated.
  3. If the fan is plugged in and seated properly, but is still not spinning, replace the processor fan.
  4. Reseat the processor heatsink and make sure the fan assembly is attached to the heatsink properly.
Processor is not installed. Power LED blinks red three times, once a second, followed by a two second pause.
NOTE: This condition indicates a missing or improperly installed processor, not a defective one.
Make sure there is a processor in the system. Reseat the processor and verify that it is installed properly. Power failure (power supply is overloaded) Power LED blinks red four times, once a second, followed by a two second pause.
  1. Check the voltage selector, located on the rear of the power supply, is set to the correct voltage (the correct setting depends on the region).
  2. Open the hood and make sure the 4-wire power supply cable is fully connected to the power connector on the system board.
  3. Check if a device is causing the problem by removing all attached devices (such as disk drives and expansion cards), then power on the system. If the system enters POST, power off and replace one device at a time, repeating the procedure until the system power failure reoccurs. Replace the device that caused the failure, then replace each of the other devices and confirm that they are functioning properly.
  4. If you cannot isolate the failure to a specific device in the previous step, replace the power supply. **
  5. Replace the system board.*
Pre-video memory error. Power LED blinks red five times, once a second, followed by a two second pause, and five simultaneous beeps are sounded
  1. Reseat the DIMMs in the memory slots on the system board, then power on the system.
  2. Replace the DIMMs one at a time to isolate the faulty module.
  3. Replace 3rd-party memory with HP memory.
  4. Replace the system board.*
Pre-video graphics error. Power LED blinks red six times, once every second, followed by a two second pause, and six simultaneous beeps are sounded. For systems with a graphic card:
  1. Reseat the graphics card and then power on the system.
  2. Replace the graphics card.
  3. Replace the system board.*
For systems with integrated (on-board) graphics, replace the system board. PCA (system board) failure. ROM detected failure prior to video. Power LED blinks red seven times, once a second, followed by a two second pause, and seven simultaneous beeps are sounded. Replace the system board. Invalid ROM based on bad checksum Power LED blinks red eight times, once a second, followed by a two second pause, and eight simultaneous beeps are sounded.
  1. Reflash the ROM using a ROMPaq diskette.
  2. Replace the system board.*
System does not power on. No beeps or blinks since the system is not functioning. Press and hold the power button for less than four seconds. Perform the following steps depending on whether the hard drive LED turns green.
If the hard drive LED turns green, then:
  1. Make sure the voltage selector (which is located on the back of the power supply) is set to the correct voltage for your region.
  2. Remove the expansion cards one at a time until the 3.3V auxiliary light on the system board turns on. If removing a card turns the light on, replace the card and then see if the system works.
If the hard drive LED does not turn green, then:
  1. Make sure the computer is plugged into a functioning AC power outlet.
  2. Open the hood and make sure the power button is securely fastened in the power harness and that the harness is connected properly to the power connector on the system board. In other words, make sure that the power button is making contact with the power circuit.
  3. Make sure the power supply cables are connected properly to the power connectors on the system board.
  4. Check to see if the 3.3V auxiliary light on the system board is not turned on, replace the power supply. **
Dec 29, 2009 | HP Compaq d530 Convertible Minitower PC...
POWER LED ON BOARD SHOWS THAT IT IS ON BUT SYSTEM DOES NOT BOOTS
Hi...
If that problem is happen check the monitor cable if it is correctly plug to the motherboard, if your motherboard have video card attach try to remove the video card, if the same things happen thee problem is the processor, you need to check the processor, remove it and clean then put a thermal paste so that the heat from processor will absorb by the heatsink, and be sure that the heatsink fan it working to prevent the heat.
Good luck !!!
Regards
PCmania
Jul 10, 2009 | Intel Desktop Board D815EEA2 Universal...
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Actually my system is having the problem like motherboard led is glowing powersupply fan processor fan spinning but when we remove memory there is no beeps from the board so what can be the problem please...
The motherboard LED is supposed to glow, indicating that the board is residually powered, after disconnection
of external power and as a warning of this condition so that you will not further disconnect or connect any
peripherals until the charge on the power retention capacitor is properly dissipated.
The Power Supply and Processor Fans should only run while power is applied, and if the Processor fan is always running at a high, possibly noisy, velocity, additional Processor Cooling may be necessary by means of a higher efficiency heat dissipation system.
If you remove memory from the board, the system should not initiate, as memory has little or nothing to do with
the problems you cite, but everything to do with the proper initiation of your system.
Buy a larger Processor Fan Assembly and those symptoms you cite which actually are problems should cure
themselves, while those symptoms you cite which are not problems will still not be problems.
Apr 18, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
Power problem
With this sysptoms u see the Processors of your system is faulty and that make your system when power on to flicker or to blink alone and switch off then you will have to replace the processor or if the processor is good then the processor Fan is faulty and it will need a replacement . bye ok
Rate this solution
You are always welcome.
Nov 06, 2008 | Gateway 4530GZ Notebook
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
Laptop won't start.
connect yr system to an external Monitor(CRT) if it comes up then yr problem might be from the inverter,backlight,screen etc.
but if it doesnt come up then yr VGA card may be damaged.
NB:u must be sure ur system is up n working by pressing the caps lock key to check if the caps lock led will light up. if it doesnt lite up then yr system isnt up n running . what yu do at this atage is to replace the ram n or processor then it should display normal.
hope this helps
thank u
May 31, 2008 | Acer Ferrari 3400 Notebook
Dell Precision 360 PC Desktop Logo
49 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
