Question about JVC AV-56P575 56" Rear Projection HDTV-Ready Television
BLACK ON SCREEN
ABOUT 2" ON TOP AND BOTTOM AND IN CONVERVENCE MODE THE GRID DOES NOT TOUCH THE EDGES OF SCREEN
  • 979 Answers
High voltage problems..Anything from bad regulator capacitance, to defective flyback transformers....accordianman
Posted on Feb 27, 2008
I can't get my tablet to open up all that is on the screen is a + sign and the home symbol and others at the bottom of the screen. When I touch the + sign it just moves to a different corner of the s
It is in touch screen configuration mode. Click on the crosses as it works out where edges of the screen are. Then it should return to normal.
Jun 28, 2014 | Kocaso Tablets & eReaders
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Im usig a asus screen VX238, when i play games like League of legends and other games there is a black stripes on the top and the bottom of the screen, the whole screen isnt displayed, How do i fix so the...
The reason is the aspect ratio that the game is set in. If you change the aspect ratio, you will lose the outer edges. A bit like cinema scope on a 16X9 screen. The top and bottom are missing by default.
Dec 24, 2013 | ASUS Computers & Internet
Bottom screen/touch screen is black
The led light has burned out on the screen and needs to be replaced. Unless you can still see light around the edges and then the screen itself needs to be replaced.
Jan 15, 2013 | Nintendo DS Lite Console
Hello, i have a panasonic DMC-TZ65. I have muliple black lines running top to bottom on the right hand side of screen, also muliple black line running left to right on the bottom half of screen. my screen...
Multiple black lines on your screens shows problem of 3" display screen. It will / may increase when ever you touch with little pressure. Sorry but there is no possibility to remove these unless and otherwise you to get it replaced if it is in warranty or by expert camera technician. I would be happy to help if you are in INDIA.
Thanks.
Oct 10, 2017 | Cameras
Getting message error -40 cant connect to itunes on my ipod 2g a1288
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device.
7. Restore ipod using itunes
Feb 26, 2011 | Apple iPod touch Second Gen (8 GB,...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
Widescreen cinema mode
Make sure the DVD player is set to 16:9 screen mode.
If you still get the bars at the top & bottom, then its probably because the DVD was filmed in true cinema widescreen, (21.7:9) whereas the TV is only 16:9.
There may be other settings on the DVD player to expnad the picture out, but you will either lose the edges of the picture, or it will be stretched.
Apr 03, 2008 | Televison & Video
Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Feb 05, 2008 | Xerox DocuColor 12 Printer
JVC AV-56P575 56" Rear Projection HDTV-Ready Television Logo
102 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
