Computer screen goes blank
I have a NEC LCD1770GX serial# 56112032TA. When I turn on the monitor I get a clear picture and a pop up that says "Video input 2D sub". Then the screen goes dark, you can barely see the contents on the screen. I tried the monitor on another computer with the same results. I really like the monitor because it has auxilliary USB ports. Can it be repaired?
  • Chuckfun Mar 02, 2008
    I took the monitor apart and found no lights. I guess I should have specified a flat screen. It appears the interior lighting is done with sheets. There is a lot of "stuff" in there that appears to be above my "pay grade". Thanks for trying, I guess I will have to bite the bullet and buy a new one.
  • Anonymous Mar 08, 2008
    vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
I never did find a solution for my problem so I purchased a new HP monitor for under $200.00 at Walmar. I was going to send it away, but I had taken it apart and the repair shop indicates it will not work on one that had been disassembled.
Posted on Mar 29, 2008
My monitor stay on for 10 minute and gose blank when is go blank I take power cord off and turn it back and stay for 3 minute
and gone agin can some one help me please my monitor is V7
thank you my email bjorche @hotmail.com
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After the scree goes dark, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 28, 2008
No video
Most likely a bad cap or inverter. This requires a solder iron and the ability to determine if the caps are bad. It also requires pulling apart a monitor with an LCD screen that is hazardous if broke. Taking it in for repairs would be costly and not worth it. I suggest trying a new power cable first and if that doesn't work you should just can it.
Sep 23, 2009 | NEC-Mitsubishi MultiSync LCD1770GX 17 in....
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Multisync 1735nxm screen dosent work
Your video card may be the issue. Can you try another monitor or try this one on another PC? This will eliminate or verify the monitor.
Mar 18, 2009 | NEC MultiSync LCD1735NXM (Silver, Grey)...
NEC plasmasync 42pd3
A Plasma Screen never need 're gassing'.
If you have verified the connections and leads are correct the the up converter is possibly faulty and in need of servicing.
Take it to an authorised NEC repair shop.
Jun 10, 2017 | NEC PlasmaSync 42PD3 42" Monitor
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Monitor not working
These messages appear during if the video cable becomes disconnected or
damaged.(most likely you will need to replace it)
Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly
Nov 14, 2007 | NEC MultiSync LCD1830 18.1" LCD Monitor
Nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Sep 24, 2007 | NEC AccuSync LCD72VX LCD Monitor
Computers & Internet Logo
1,184 people viewed this question
David Payne
David Payne
