Question about Bose Lifestyle 30 System
Hdmi conflictng with optical
Guys
I have the new bose V30 sysem I have an issue where when I connect a sky satelite box to the v30 system via optical (sky only transmit 5.1 dts via optical) and then connect video via hdmi. The hdmi downscales sound to pcm 2.0 :-( if change video to component it works! but i lose out on picture quality on HD broadcasts as I have a full HD screen.
Any advice?
gdhariwal@gmail.com
system is actually bose V30!!
    New Friend:
There are different qualities of HDMI cables. one that is a version 1.3 will not be able to properly transmit as well as a version 2.0. digital transmission is only as good as the conduit that it must travel through. if you loose quality it might be because your asking your wires to carry more than it can.
Posted on Nov 26, 2013
  • 492 Answers
Use the component. If your tv is running correctly it should not lose quality through the component system. HDMI is simply a High Def Multiple Interface, meaning that it combines the Visual with the Audio signal in the same cable. Refer to your documentation on your sattelite box to see if there is a solution. But remember that the HDMI may be carrying what the actual broadcast sound is as not many if any channels are transmitted in 5.1 dts.
Posted on Mar 07, 2008
Tip
Bose LifeStyle V30 Manual Download
Download Bose LifeStyle V30 Audio System Manual
Would you like to review the features of the Bose LifeStyle V30 Audio System?
Have you lost your Bose LifeStyle V30 Audio System Owners Manual?
Would you like a digital, searchable, pdf version of the Bose LifeStyle V30 Audio System Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bose LifeStyle V30 Audio System documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Bose Lifestyle V30 Home Theater System -...
No video at all!
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues, including HDCP (High Def Copy Protection) through HDMI issue. Component cabling should eliminate this problem.
I hope that helps.
Download Bose LifeStyle V30 User Manual
May 31, 2010 | Bose Lifestyle V30 Home Theater System -...
I have installed the v30 bose lifestyle system but I can not get any video output on my Samsung led tv. I have tried the hdmi cable and the component cable. It both doesn't work.please help me with this
I recommend you stick with component cabling.
Having no picture at all generally suggests the V30 is trying a video mode your TV does not support:
  1. video type (PAL or NTSC)
  2. Progressive scan
  3. an HD resolution beyond your TV's range.
I hope that helps.
May 21, 2010 | Bose Lifestyle 30 System
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Feb 06, 2010 | Bose 36037 Remote Control
I cant get sound out of the Bose V30 and i lost the cable picture on Tv. What do i do?
I lost the video (HDMI) but can get all my sounds (TV, DVD, Radio, etc). HDMI cable is fine because it worke when plugged from cable box directly to the TV. Any suggestions?
Dec 22, 2009 | Bose Lifestyle V30 Home Theater System -...
Have audio through TV can't get audio through Bose
It sounds like your signal path from the dvd is going through your TV, rather than through your Bose V30. Either find an audio out port on your TV and route it back to an aux in on the V30, or, preferably, run your DVR and your DVD to the V30, and then from the V30 to your TV.
I hope that helps.
Dec 12, 2009 | Bose Lifestyle V30 Home Theater System -...
Connection to Bose V30 System
check hdmi setting from ur tv and ur dvd connection
Nov 08, 2009 | Bose Lifestyle V30 Home Theater System -...
Flashing / ghosting with Bose Lifestyle V30
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues. Component cabling from your devices should eliminate your problems.
I hope that helps.
____________________________________________
Mar 15, 2009 | Bose Lifestyle V30 Home Theater System -...
Apple TV and Bose Home Theater
You should be able to connect hdmi from apple tv to bose v30 for picture and sound. You can also run component video to bose and a hdmi out of bose to tv. Just make sure your running hdmi out of bose system to tv if your tv supports hdmi if not use component video cable. Another way which isn't as good of quality is to run fiber optic from apple tv to bose v30 and hdmi straight to tv.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 02, 2008 | Bose Lifestyle 30 System
Bose Lifestyle 30 System Logo
379 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
