Question about Minolta magicolor 2300W Laser Printer
T?che suspendue sur Minolta magicolor 2300DL
Le tableau indique toujours «toner usagé plein» alors qu'il a été proprement vidé et remis en place. Comment désactiver ou corriger le senseur pour terminer une tâche? Merci!
Bernard C.
  • BONNEAU Feb 28, 2008
    I'll try in english (sorry for the french accent!). It refers to my MINOLTA Magicolor 2300 DL
    A printing job has been interrupted with the signal ''waste toner box full''. It was in fact just half full ! Come on, I'm not blind!
    Even after having emptied the box (as already done once before), the signal stayed the same and the printer didn't start printing again.
    How can I bypass the sensor and its signal in order to finish the printing job?... I Imagine there is a way to do it without having to by a brand new box again. If not, the printer will go straight to the garbage bin, the big one! Would it be the best and only solution?
    BONNEAU
  • BONNEAU Mar 03, 2008
    Sorry! The suggestion didn't work. I have carefully followed the instructions and realised that everything was perfectly clean inside. With the box back into its place, the message stayed the same: «waste toner box full». I suspect that the problem might come from somewhere else, maybe with the sensor itself ! Is there another 'easy' way to check that?
    Thanks again for your help! The printing task srtill has to be completed...
    BONNEAU
Take out the box. Empty it. Then rinse it out with water. This will clean the inside and the sensor will now know its empty. Its a bit of a dirty job though.
Posted on Sep 08, 2009
    Champion:
  • 214 Answers
Can you post it in englist pleas ?
Posted on Feb 28, 2008
  • Illar Lumiste Feb 28, 2008
    your english is ok, but the best solution would be:
    if you remove the waste box you'll see blue knob and above there is a sensor now take a look at the waste box and find the place what goes between the sensor. you should cut off one side and clean the other sides and then use some invisible tape to fix the hole. and try again.
    so anyway the point is this place what goes between the sensor have to be clean. its not good idea to cut or remove the sensor at all because next time the box will be full you don't know that and it will brake your printer.
    good luck
  • Illar Lumiste Mar 03, 2008
    Yes, there can be a problem with sensor so you can do the following: remove waste toner box and the cover where the sensor is (black screws) and place the sensor somewhere else, but do not disconnect it and then put the waste toner box back if needed clean the sensor before. because this is the only sensor what reads the box full/empty state.
J'ai besoin de code de reinitialisation de ce nokia
Salut Anonymous, Si vous avez verrouill? votre t?l?phone par le biais d'entrer un nombre incorrect de broches 3 fois alors vous avez besoin d'un code Puk, Anneau de votre fournisseur de service et ils vous donneront le code GRATUIT Puk .....
Si vous verrouillez votre t?l?phone ? nouveau un peu de temps ? l'avenir et vous ?tes toujours avec le m?me fournisseur de services que vous pouvez utiliser ce m?me code Puk .. MAIS si vous avez oubli? votre code de motif Le lien ci-dessous est une vid?o sur youtube d'un mec 3 voies, mais la 3e voie est une r?initialisation d'usine signifie que vous perdez chaque chose dans votre t?l?phone
mais les deux premiers moyens sont ? surveiller. Aussi il y a des vid?os sur le c?t? droit qui peut aider ..... J'esp?re que cette aide ...... ACCLAMATIONS ..
EASY WAYS How To Unlock Android Passwords
Apr 24, 2016 | Nokia Cell Phones
J'ai une imprimante Minolta Magicolor 2300DL (5-6 ans). PROBLÈME: refuse de fonctionner car la fenêtre affiche «toner usagé plein». - le contenant avait été bien...
Your languAGE IS NOT understandable can you post your problem in English (US). I think you have problem in fax machine but cant understand your problem
Oct 03, 2008 | Minolta Office Equipment & Supplies
Tip
Messageries instantan?es : bien d?buter avec Windows Live Messenger ...
Messageries instantanées : bien débuter avec Windows Live Messenger
MSN a changé de nom et est devenu Windows Live Messenger. Son utilisation est toujours aussi intuitive, n'hésitez plus à vous lancer. Retrouvez notre tutoriel pour bien l'installer et faites vos premiers pas dans le monde des messageries instantanées.
L'installation : facile comme un clic Il faut avant tout ouvrir un compte chez hotmail ou MSN c'est-à-dire une adresse mail, pour pouvoir se connecter. Il s'agit de votre compte Passport qui vous servira d'identifiant pour entrer sur le réseau. Vu le nombre d'utilisateurs, qui augmente considérablement avec le temps, il devient de plus en plus difficile de choisir un nom qui ne soit pas déjà utilisé. Soyez créatifs mais n'oubliez pas que le nom que vous choisirez sera communiqué à toutes les personnes avec qui vous souhaiterez communiquer. Depuis peu Il est également possible de se connecter avec un mail qui ne provienne ni d'hotmail ni de msn et on peut aussi bien directement se connecter via le web sans rien télécharger (mais sans avoir toutes les options). Ensuite il vous suffit de télécharger le logiciel ici.
Suivez les indications pour l'installer, puis double cliquez sur l'icône dans le bas de votre écran à droite. Entrez l'adresse de messagerie et le mot de passe enregistré avec votre compte Passport. Il reste à vous faire connaître auprès des personnes qui ont déjà MSN.
1.jpg Cliquez sur l'onglet Contacts en haut à gauche puis sur ajoutez un contact Pour ce faire, cochez la case en bas et entrez l'adresse de messagerie du contact que vous souhaitez ajouter. Le contact s'ajoute automatiquement dans votre écran principal, il vous suffit ensuite de le placer dans la catégorie qui vous convient (amis/collègues/famille/autres contacts...)
Avant de pouvoir lui parler, sachez qu'en l'ajoutant vous venez de lui envoyer un message lui demandant s'il accepte d'être ajouté dans votre répertoire. Si la personne accepte (ce qu'elle devrait normalement faire) vous recevrez un petit message de confirmation. "X a accepté de devenir votre ami". Ce petit message vous confirme que vous ne vous êtes pas trompé de messagerie en envoyant votre message.
Premières conversations Une fois tous vos contacts ajoutés, retournez dans la fenêtre principale de MSN Messenger, double-cliquez sur le nom d'un contact en ligne pour lui envoyer un message. Vous écrivez dans la partie inférieure, une fois envoyé le texte apparaît dans l'écran du dessus et vous pouvez suivre la conversation en continu.
2.jpg Notez qu'une utilisation répétée de MSN est une bonne techniquepour apprendre à taper plus vite sur un clavier. Il ne vous reste plus qu'à entamer la conversation. Vous pouvez voir sur la photo les coordonnées du contact ainsi que les options offertes par messenger... envoyer des fichiers, démarrer une conversation audio ou vidéo. Vous pouvez parler à autant de personnes que vous le souhaitez, double cliquer sur un contact ouvrira à chaque fois une nouvelle fenêtre pour parler en tête à tête... Vous n'êtes limité que par le nombre de vos contacts et votre capacité à gérer plusieurs conversations en même temps.
Autre possibilité : vous parlez à une personne et vous souhaitez inviter un autre contact (ou plusieurs) à participer à votre conversation. Là encore, la simplicité règne. Il suffit de repérer la petite icône "inviter" qui se trouve juste au dessus du nom de votre contact dans la fenêtre de discussion. Vous tombez sur une autre fenêtre regroupant la liste de vos contacts en ligne, sélectionnez la personne que vous désirez inviter...et c'est parti. Recommencez autant de fois que vous le souhaitez.
on Oct 09, 2010 | Microsoft Windows Live Messanger
Quelle sont les etapes que la manette universel fontione
Lorsque vous souhaitez programmer un dispositif trouver le premier code.
Ensuite, appuyez et relâchez le bouton que vous souhaitez attribuer le code,
Ensuite, appuyez et maintenez enfoncé le bouton SETUP jusqu'à ce qu'elle occupe une lueur.
touché les numéros de code. il devrait clignoter deux fois, en indiquant un code de bonnes.
puis cliquez sur le bouton que vous venez de configuration, et le diriger vers le périphérique, et cliquez sur le bouton d'alimentation.
Si elle vient, vous avez choisi le bon code
Il ya généralement plusieurs codes pour une marque, afin de les essayer tous, un par un jusqu'à ce que vous avez.
Répétez la procédure pour d'autres articles. Soyez sûr d'assigner une touche différente et appropriée labeld.
Aug 31, 2011 | One For All URC4110 Remote Control
Le son des hauts parleurs ne fonctionnent plus etc,est un modele de logitech ls21
Bonjour bouscotte
Je les testerais d' abord sur un autre pc pour voir si le mal vient bien des HP . Si oui , ne connaissant le modèle par coeur , je suppose qu' il y a un sub . Vérifie s' il n' y a pas un fusible de sécurité et vois s' il est toujours intact . Les connections sont à contrôler .
Après cela , je ne vois qu' une panne de l' ampli dans le sub mais c' est peu probable . Je pense plutôt à un disfonctionnement de la carte son ou bien le son est coupé accidentellement . Clique sur l' icone du hp dans la barre des tâches en bas à droite de l' écran et vois ce qui se passe dans le mélangeur . Si tout est normal à cet endroit , il ne reste plus que la carte son . Vérifie le pilote via le gestionnaire des périphériques . Remplacer la carte son , si nécessaire , ne coûte pas cher .
Bon courage ,
fanaudi .
Mar 25, 2011 | Audio Players & Recorders
Bonjour je viens d aquerir une imprimante ricoh gx 3000sf sur une vente aux enchere et le probleme que j ai actuellement c que quand j allume mon imprimante elle se met en securite et m indique sur l ecran...
Bonjour , latasca09
L' imprimante est sans doute bloqu?e par un objet ( morceau de papier ) coinc? dans les rouleaux . Je ne suis pas familiaris? avec ce mod?le mais il faudrait enlever le couvercle pour acc?der aux rouleaux et voir ce qui se passe . Un simple bout de papier ( souvent du collant ) suffit ? provoquer la panne .
La m?canique doit ?tre impeccablement propre .
Il faut aussi v?rifier si le pilote correct a ?t? valablement install? , notamment en fonction du syst?me d'exploitation .
Je d?brancherais l' imprimante pour commencer et desinstallerais le logiciel/pilote . Faire ensuite un red?marrage de l' ordi . R?installer le logiciel / pilote et rebrancher l' imprimante apr?s installation .
Attendre confirmation que le pilote a ?t? install? correctement .
Verifier aussi dans le gestionnaire des p?riph?riques s' il n' y pas un probl?me de pilote .
J' esp?re que ceci pourra t' aider .
Cordialement ,
fanaudi .
Mar 20, 2011 | Ricoh GX3000sf InkJet Printer
J'ai un code erreur 5200 .... quoi faire ?
Ce code d'erreur vous dit que l'unit? de purge n'a pas compl?t? un bon pouvoir sur le cycle et la came n'est pas dans la position correcte. Typiquement ceci signifie que l'unit? de purge est enfonc?e prolong? en raison de l'accumulation de beaucoup d'a s?ch? de l'encre.
Ouvrir la couverture et quand la t?te vient au centre, tirer le cordon d'alimentation. Une fois ce pouvoir est de peut vous transf?rer maintenant la cal?che ? l'extr?me gauche si c'est ? un endroit o? il ne vous g?nera pas. Maintenant utiliser une serviette en papier et tacher doucement toute l'encre suppl?mentaire de des Coussins d'encre et les appuie en bas. Si la lame d'Essuie-glace est ?tendue, le nettoie et il devrait claquer de retour en place. S'il est toujours enfonc?, essaie vaporisant le secteur avec Windex mais n'importe ne lequel obtient pas sur n'importe quoi sauf les coussins.
Nouvel An heureux !
Si je pourrais ?tre de plus ample assistance, me permettre de savoir. Si ceci aide ou r?sout le probl?me, s'il vous pla?t l'?valuer et donner un t?moignage pour ma r?ponse.
Merci, Joe
Jan 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
Bonjour , nous avons un Asko D-3120 j'entend le moteur fonctionner mais rien ne se passe a l'interieur et la lumiere de la tasse avec une assiette clignote sans arrêt . J'ai essayé...
le drain est boucher et la panne de reserve est pleine d'eau solution sort le lave vaisselle de sont emplacement et enleve le panneau arriere ensuite éponge l'eau et débranche le tyau de drain place le tuyau de rain dans un sceau et demarre un cylce de rincage et verifier si il ne coule pas lors du cycle dans la panne
Nov 01, 2010 | Asko Dishwashers
Iris problem with PT-AX100U projector
le probleme est du par les pivots de l`iris qui manque de lubrifiant. il a deux pivots a lubrifier, le premier se lubrifie sous le projecteur dans le compartiment de la lampe.
il est de couleur brun et il a un petit resort autoure de lui, il est en plastique. prendre un micro
tournevis et le faire fonctionne. il doit revenir sur lui meme rapidement,lentement pas bon il faut
le lubrifie. seulement une petite goutte suffit.
le deuxieme est plus complique,il faut ouvrir le projecteur. les vis sont sous le projecteur indique
par des fleches. il en a une autre sur le dos .attention il est difficile de separer les couvercles
on peut voire le pivot sous une petite grille de metal il est brun lui aussi
ps prendre le tounevis pour applique le lubrifiant atf dextronIII
Oct 23, 2008 | Televison & Video
Cam?ra embroyer..
Pourquoi les images provenant de la caméra sont-elles déformées, floues, granuleuses ou décolorées? trnsp.gif Réponse Plusieurs facteurs ont une incidence sur la qualité de vos images. Si les images sont floues, réglez la bague de mise au point située autour de l'objectif. Vous pouvez ainsi réaliser la mise au point sur des objets situés à des distances différentes. Veillez également à ce que l'éclairage soit adéquat. L'amélioration des conditions d'éclairage influe considérablement sur la qualité des images.
Si la qualité des images est médiocre pendant une transmission vidéo sur Internet à l'aide de programmes comme MSN Messenger, Yahoo! ou AOL Instant Messenger, votre vitesse de connexion à Internet a une incidence directe sur la qualité de la vidéo transmise. Les connexions d'entreprise de type modem câble, DSL ou RLE permettent d'obtenir d'excellents résultats en termes de qualité d'image, alors que les connexions commutées engendrent une qualité globalement médiocre et instable en raison de la lenteur de la connexion. Il peut arriver que la vidéo soit instable même avec les connexions haut débit (comme DSL ou modem câble) en raison du trafic Internet ou de la lenteur de téléchargement. Si l'image apparaît clairement sur le logiciel de la caméra, il est fort probable que votre connexion Internet soit à l'origine de la mauvaise qualité des images dans votre programme vidéo.
Si malgré tout, les images obtenues sont toujours déformées, floues ou granuleuses, vous devrez peut-être modifier les paramètres d'affichage. Pour une qualité optimale, vérifiez que la résolution est réglée sur Moyenne (16 bits) ou plus. Pour modifier la palette des couleurs:
  1. Cliquez sur Démarrer, puis Paramètres et Panneau de configuration.
  2. Double-cliquez sur l'icône Affichage.
  3. Cliquez sur l'onglet Paramètres.
  4. Dans la section Qualité couleur, vérifiez que l'option Moyenne (16 bits) ou Elevée (24 bits) est sélectionnée.
  5. Procurez-vous également les pilotes les plus récents auprès du fabricant de votre carte vidéo.
Si vous ne pouvez rien faire pour améliorer les conditions d'éclairage, certaines caméras vidéo Logitech sont équipées de l'option Optimisation de la lumière variable. Si tel est le cas pour votre caméra, activez l'option Optimisation de la lumière variable dans le logiciel QuickCam. Pour ce faire, procédez comme suit:
  1. Lancez le logiciel QuickCam.
  2. Dans l'angle inférieur droit de la fenêtre vidéo, cliquez sur la flèche en regard de l'icône QuickCam.
  3. Sélectionnez Paramètres de caméra avancés.
  4. Dans la section Amélioration de l'image, activez l'option Optimisation de la lumière variable.
  5. Si la qualité des images ne s'améliore pas, essayez de régler les autres paramètres, tels que le contraste, la saturation, la luminosité, le gain et l'équilibrage des blancs.
  6. Cliquez sur OK lorsque vous avez terminé.
Enfin, vérifiez que vous utilisez la version la plus récente du logiciel
Mar 03, 2008 | Logitech QuickCam Communicate STX Personal...
Minolta magicolor 2300W Laser Printer Logo
164 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
