Question about Refrigerators
Sub Zero side by side loud noise when the fan/motor is running
It always ran very quietly and now when the motor kicks on it's much louder - no banging or clicking just sounds like a beat up motor - when I open the panel above - it doesn't look like I can easily access anything (blocked by a large white panel) i thought maybe I could check filters, fans etc. for debris or wear. Help! Thanks.
The freezer side of my Sub Zero is rattling. It stops when I open the door. I've checked for overloaded shelves or something in the way. That doesn't seem to be it. My model is a 680F.
  • THERESAKELLY Jan 07, 2009
  • francis rivero May 11, 2010
    can you see a frost at the back wall of the freezer section/
  • 21 Answers
Good day, Nancy
In addition to what the good drcool indicates, try this too.. When you open the door, it is going to cause an overall shift in the weight to the Cabinet. That's why the noise disappears. What causes it, is the compressor running (that's Normal) the noise is from metal that is just right distance away (about the thickness of a credit card) which needs to either held tight against the cabinet, or further away . It Doesn't mean you're going to have a problem with the unit functioning, but the noise could bother you to the point of..... 3 choices... refer to you're care book, under how to level and follow what it says. Often just a slight adjustment to how its sitting there at rest will correct you're problem. looking above where condenser's located... or the water supply if you have one, sometimes moving it... I would go with the 1st option first.. the others are a little more involved then perhaps, it sounds.. also don't forget to look to see if there is frost on the back wall of the Freezer, Ice maybe forming up the and hitting the fan blade... as was suggested by drcool...thanks for asking.... dean
Posted on Feb 27, 2008
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ... > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
Laptop making loud fan noise like its overheating,
Go buy a can of compressed air and blow out the fans and vents. That should get it running quiet again.
Jun 08, 2012 | Acer Aspire 5336-2524 Intel Celeron 900...
My 10yr old model#690 freezer is having trouble maintaining temp and when the compressor shuts off it makes a loud clunk noise. I have check to see that fan is running and have turned unit off for about...
The noise that you are hearing is in the compressor. The motor has rubber mounts that hold the motor inside the compressor. One of these mounts are broke and what you are hearing is the motor hitting against the inside of the compressor. Have you tried cleaning the coils? let me know.
Mar 06, 2011 | Sub-Zero 690 Side by Side Refrigerator
Just had the condenser fan motor replaced on my 550 sub zero refrigerator. I forgot to asked the serviceperson the following questions: Does the fan continously stay on and what is the normal sound of...
Good day,
On models with 2 compressors the condenser fan motor runs 24/7. It must since the compressors run randomly and that motor must be on since it handles both units.
Fan noise is subjective. It itself makes little noise but the blade does. If for example the blade was changed from the nylon style to a metal blade (good idea) then it would be somewhat louder.
If the noise is not objectionable then I would use it as is.
Oct 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
NEW HIGH SPEED EVAPORATOR FAN MOTOR TOO LOUD Repair technician told me there were problems with the original evaporator motor and replaced it with a new high speed one. Now the fridge is too loud. Before...
It's the rotors making the noise not the motors! I replaced the motor, still made noise, I took off rotor blade sanded it down around each blade, no more high pitched hum!
Jan 12, 2010 | Frigidaire FRS26H5AS Side by Side...
Sub zero 695 freezer not freezing.
There are a couple of possible problems. If you mean load motor noise as in the compressor then you likely have a sealed system problem. Either a bad internal valve is making it noisy and you are loosing presure within the system. You will need a new compressor if this is the problem. A technician could tell you if this is the problem just by checking the internal low side presures. A few things that I would check before calling a technician is 1. Make sure the condenser fan in the upper unit is running. 2. Check to see that the internal fan in the freezer is operating as well. 3. Check to see that the freezer light is going off when you close the door. If all of these things are working I would suggest call a technician.
Dec 13, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
sound like you condensor fan motor is going out... it might be a Compressor problem.. .check the condensor fan motor and proper air flow..
Nov 13, 2007 | Sub-Zero 661/F Side by Side Refrigerator
more likely a bad compressor, which is more sensitive to temperature extremes...may be cheaper to replace the frig.
Jun 10, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
2,211 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
