DIBOSS tv shows no picture
My tv does not show a picture (black picture only, sound works fine) however when you step through the AV channnels, etc and get back to the tv screen the picture does appear for 2 seconds and then goes black, (so it doesn't seem to be a problem with the display but the signal link to the display??). It did correct itself recently for about 20 minutes but went black again.
Regards
Iain B
  • 3 more comments
  • Anonymous Mar 13, 2008
    I have got exatly the same problem with this device.
  • Anonymous Sep 08, 2008
    I have the same problem to but my screen stays black no mater what i try but the sound works fine! I cant even reach the menu or do anything ells!
  • nerina_m Oct 21, 2008
    Exactly the same problem occurred yesterday with my four year old Diboss tv. We got glimpses of a picture then nothing, but the sound is still fine - I'm wondering whether it's economically repairable or if we should just give up and get a new one.
  • Anonymous Dec 13, 2008
    Screeen goes black, stays on for a couple of minutes, when chganging channels it can go on, but problem has grown worse and now only pic for a few sec's, sound is fine.
  • Anonymous Mar 23, 2014
    it is a 3d tv also
Me too! Apparently Diboss are no longer trading, so no help there. I am aware that these panels have a common power supply issue, the faulty chip is only available from China and the last one I fitted only lastest a couple of days. However the fault described above is not the same. I've checked the psu outputs; all are fine and nothing changes when the picture disappears, therefore I can assume that I'm not looking at a PSU fault. As Iain says above, it appears to be a signal link, however I have no picture on ANY input and without circuit diagrams I cannot find any component that's common to all the various inputs. This leads me to think that either the backlight, or the screen itself is faulty. I'll keep trying and if I get it sorted I will report back.
Jon
Posted on Sep 24, 2008
Magnavox 15mf400t 37
Check the other sources first - AV, scart, hdmi, etc. If you get the same result your main AV board needs replacing or repairing.
Jun 17, 2013 | Televison & Video
Tv wont show pictures on any channels but has AV showing and i have picture sound how do i correct this problem
Hi , do you have an aerial plugged into the tv either for cable tv, sky tv, or freeview etc?
Sep 07, 2011 | Panasonic Televison & Video
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
TV has no picture, but sound works fine
Are you using the AV input for the XBox or other cable? If you use AV, then use the same input that the Xbox does not show picture, plug in a DVD and see if it works. If it does not have a picture, so 100% your TV has problem.
Aug 11, 2009 | Sony Televison & Video
Sound but no picture on either SCART socket inputs
open the tv and check for dry joints on the jacks of AVS, if no dry joint is found
the ariel in put is different from AV inputs
change the AV in IC. AT THE W/SHOP
Apr 25, 2009 | Goodmans 257NS 20" TV
Tv picture is black, sound is fine
Sorry, no easy answer here. On an older set this would be espected and not worth repairing, but you should take this to a TV shop for troubleshooting. Most likely culprit is the flyback transformer and/or the horizontal deflection.
Hope Ya Fix It.
Jan 31, 2008 | JVC AV-27F702 27" TV
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
Televison & Video Logo
1,311 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
