Question about Nokia 2610 Cellular Phone
Cellphone reformat how to reformat/reprogram nokia 2610??
  • Anonymous Apr 15, 2008
    how cana i reformat my 6600 cp
Hi i
am sher singh and i do the cell phone formatting reprograme
Posted on Apr 08, 2008
I would like to know the master unlock code for: Nokia Model No. --- Nokia 2610b IMEI No. --- 011040001519993 please.
No such thing as a master unlock. Do a hard reset.
Search Results
NOKIA 2610 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/nokia/nokia-2610/hardreset/first-method/ Next press and hold * key + 3 key + Call button + Power button, until you see Nokia logo. HardReset NOKIA 2610; Now enter your lock code. * The default lock ...
NOKIA 2610 - Device Codes - HardReset.info
www.hardreset.info/devices/nokia/nokia-2610/codes/ Codes for NOKIA 2610. On the main ... Displays Serial Number. 2. Displays ... If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
May 12, 2018 | Nokia Cell Phones
I use this code'*#9990 in my nokia 3110c mobile
Hi, your problem is need to reprogram your cellphone or try this also maual reformat to your cellphone just dial this *#7780# and default password nokia 12345.but before you that reformat you need to back-up your files to memory card and save your contacts to sim memory.after you that the cellphone is back to normal setting .i wish that i help your problem.thanks
Jul 23, 2011 | Nokia Lands Phones
Nokia 3110C phone shut down and wasn't able to turn it on again.. it was just a blinking light.. how will i reformat the handset with the phone off?
No you cannot Format this thing..there is no other solution without flashing.So read carefully and do it
First download and install Pheonix. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / programme files/pheonix..after finished this installation open pheonix clip_image002.gif Inside the interface at the> left top <there you see "File" click there and choose "open file" and then select the approprait Product type i.e"which is written in the back banel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there when you click there you'll see three icon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found just take one.After this you can see "Dead phone USB flashing" click that box.Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" after this, a message will prompt you "press power botton" press it and wait untill the phone will Restart automaticlly in normal mode 10-15 minutes.If you cannot understand just make a Reply thanks for visiting fixya.Good luck
Jul 13, 2011 | Nokia 3110 Cellular Phone
I can't access to delete the Security Code Nokia 1280
Try to consult a cellphone repairing shop to reformat/reprogram your Cellular Phone
Jan 31, 2011 | Nokia 1208 Cellular Phone
How o reformat/reprogram a nokia3310c
If your able to switch on your phone then try this:
To reset your Nokia phone please follow this.
Press *3370#
It would reset the phone to factory settings.
The default code is 12345
or
If your phone is not starting please press these buttons simultaneously.
on/off + * + 3
Jul 31, 2010 | Nokia 3310 Cellular Phone
My nokia n7373 send to many same messages.why?
hi,
your cellphone may facing a software problem..removed your sim then insert it again..lets reset first before we are going far ,go to menu , setting ,factory setting ,then enter security code..if not change the default is 12345...test the phone ,send a message ,if still the same problem reformat your phone ,type *#7370# then enter your locked code ...test the phone again by sending message ...if thge problem is still there ,its the time to go to a nokia care center to reprogram your cellphone..i hope it will help you..thanks
Jun 17, 2010 | Nokia N73 Cellular Phone
How to format my nokia 2610 cellphone?
You can reset the menu settings to their original settings:
select Menu > Settings > Restore factory sett..
Mar 09, 2010 | Nokia 2610 Cellular Phone
I have lost entire inbuilt original data in my nokia 5220 mobile after selecting "restore all"" in "settings "menu what shold i do now? someone help me please
reprogram your phone through the use of manual reprogramming..
this is what to do...
press *
press "call"
press 3
press "end call"
and then switch on...
press all the given key in one pressing..
if the reformatting appear,, hold on all the pressing key until it will finish reformat.
Oct 25, 2009 | Nokia 5220 XpressMusic Cellular Phone
Unlock Nokia 2610
hi
here is the solution
Warning: Do not enter any wrong unlock unlock codes on your Nokia 2610 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2610 mobile phone without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2610 mobile phone.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2610 mobile phone would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2610 mobile phone
Each Nokia 2610 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 2610 mobile phone at www.mobileunlocksolutions.com. hope you do please rate me thank you...
Sep 20, 2009 | Nokia 2610 Cellular Phone
Nokia 2610 Cellular Phone Logo
298 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
