Question about HP LaserJet 1300 Printer
My laserjet 1300 burnt
I had fluctuation in power supply and the printer started burning and i put it off, since then i cant put it on again. Its not coming ON
  • emmayobjc Feb 28, 2008
    how are my going to change the power supply unit and how expensive is that
  • 152 Answers
B'coz of your printer power supply goes to down
replace powersupply unit
Posted on Feb 28, 2008
  • Harshad Patel
    Harshad Patel Feb 28, 2008
    contact your hardware engineer for price and replace power supply
    power supply fited on printer metal base body
Please sir, I need the service manual for hp laserjet 1300 printer
If you need service for your hp printer. you may visit HP Customer service or dial toll free number- 1-800-585-2494. hope this will help you better.
Jun 10, 2014 | HP LaserJet 1300 Printer
HP Partsufer
Tech guys only.. Remove rare,side,top covers, rare metal sheet cover, you can see the Low vol power supply, check input 220V/110V(depends power standards) fuse. If fuse burnt check primary section is there any component failed? replace same rated fuse the try it.. if successful no issue, if fuse burnt repeats replace "Power Supply".
If fuse burnt after fuser drive starts, replace another fuser then try it. (faulty fuser also one of the cause to fuse burnt)
Jul 11, 2012 | HP Color Laserjet 5550dtn Printer Laserjet...
Modifying Power Supply for 220 to 110
If you cannot get a ECU board from HP to replace the 220 volt model.
Then
The easiest solution, use a stepdown transformer fro 22m to 110 volts. Make sure the stepdown ransformer has a power rating that can supply enought watts to run the printer.
Mar 25, 2012 | HP LaserJet 1300 Printer
Hp 10a8 printere power supply these componants are always getting burnt
Check for home ac current not fluctuating, this can occurred power adaptor to burn, or need to check for possible short ckt or electric motor near or utilizing same line of wall socket.
Mar 23, 2010 | HP LaserJet 1018 Printer
We had a brown out at my office and now my MX700 Canon will not even light up.
Either there is a burned out fuse or the power supply will need to be replaced.
Jul 10, 2009 | Canon PIXMA MX700 All-In-One InkJet...
HP Color LaserJet 4500 Printer
Here is your problem. Hope that this helps you.
54.1 PRINTER ERROR
Description:
Indicates that an internal power failure has
occurred.
Action:
1. Turn the printer off, and then turn the printer
back on.
2. Replace the high-voltage power supply.
3. Check the fuser to ensure jams have not
occurred.
Caution When clearing jams, the
thermistor can be damaged
causing this error.
4. Make sure there is not a fluctuation in the
power supply to the printer. Check that the
electrical specifications (see Chapter 1) are
met.
5. Replace the low-voltage power supply.
Apr 02, 2009 | HP Color LaserJet 4500 Printer
Ghost prints on HP-1300
The cartridge could be bad. Just saw same issue earlier on another HP doing the same. Inspected the fuser and it had a place it the middle that the teflon coating was worn off. Try cartridge first, then look at the fuser with flashlight. Do not stick anything into the fuser. Make sure machine is powered down,unplugged and allow it to cool down before attempting to touch area. It will burn you, they get hot!
Feb 13, 2009 | HP LaserJet 1300 Printer
Installer of hp laserjet 1300
dear all
i need install of laser jet 1300 printer urgently
please help me
May 09, 2008 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
