Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
LG WASHING MACHINE WM14225FD
posted by CONGOLOVER on Feb 27, 2008
Our machine blew its fuse and trip switch on master board. New fuse in and socket checked but now wont even switch on. No lights, no beeps, no nothing.
Can you help please?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 27, 2008
Thanks for Trying (70)
Coldcut
Rank:Wiz Wiz
Rating: 84%, 512 votes
Once a fuse blows on any equipment it usually means the power supply diodes and/or capacator is bad.
but this unit has several 110 volts UJT transistors and relays throughout the board that can cause the same issue.
replacing the CCU (computer control unit) is easy its just the pricing that will bug you.
its around 225.00 on the low end.
taped to the side in the bottom of your unit ,open the bottom access panel, is a schematic.
the ccu is accessed through the top access panel.
Before you replace the CCU a contunity check must be made of all the connected wiring to the CCU board. in case one of the other controls caused the failure.
nothing like replacing a board and watching it fry again.
The manual for this unit give the readings you should expect.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on LG WASHING MACHINE WM14225FD:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
I have been told that it will probably be the brushes in...
Indesit W 123 Front Load Washer
e erything else ok but door completely locked
Washing Machines
our samsung p1053 washing machine keeps locking up and...
Whirlpool Duet GHW9150P Front Load Washer
I keep getting the code F-1 Whirlpool Duet washer...
Washing Machines
Whirlpool awm 8121 7 kg front loader worn drum pully req...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
