Question about Panasonic Panafax UF-490 Plain Paper Laser Fax
Copy Quality I have a thin black line on all copies. The fax is new, the scanner area is so clean it could just have come from the factory, have checked and no tippex etc on the lens, there is no loose toner. Any suggestions
    Sergeant:
  • 284 Answers
Try doing an internal printout. press function-6-4-start- and if there are lines on that paper that prints out. you need to replace the drum on the machine.
Posted on Nov 24, 2008
  • 31 Answers
Just clean the scanning unit glass
Posted on Mar 11, 2008
    Scholar:
  • 159 Answers
The CIS scanner has one of the LCD bits bad. If it is new, claim a warranty repair. Otherwise, strip the scanner out and go over all the solder joints
Posted on Feb 29, 2008
Hpl7780 how to clean scanner, thin black line on copy
Lift up the cover on the document feeder and you will see a thin glass strip. Clean this with Isopropyl alcohol or alcohol based hand sanitiser. The line is caused by Whiteout, Tippex, part of a label or something similar.
The HP website has other ideas, but I am usually right :>)
HP Printers Fixing Copy Quality Issues
Mar 26, 2017 | Black Office Equipment & Supplies
When I receive a fax, it prints out perfectly. When I make a copy or scan to fax/email, the page has multiple black lines running down the length of the page. I have recently replaced the drum and the...
As the fax receives and prints incoming faxes ok then the print engine is working ok. the fact that the problem arises when copying or scanning indicates the problem is with the scanner or software that controls the scanner.
First clean both scanner glasses and the white area (white reference) under the doc feeder. When you are happy all is clean, follow the following instructions:
Press menu, * 2864 within 3 seconds. the display will show "Maintenance"
now press 55. The scanner will initialise and go back to "Maintenance"
now press 99 and the machine will go back to the default screen showing date and time.
Now do a copy. if you still have the lines or its all black then you will need a new contact image sensor. If all is well then that was a good cheap repair.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
The faxed copy has a big black line in the middle of the paper. A new toner and a new drum have been installed but the line is still there. Help! Ruth
Clean the scanner glass. This is the smaller piece of glass that is located just to the left of the large original glass. Or if you have an older or smaller model Brother the strip of glass is going to be located under/inside of the port where your documents are fed into the machine. This operation panel usualy just pops open and you can find the strip of glass inside. Just clean it with a bit of glass cleaner that has been sprayed on a soft cloth. Make a copy with the machine to test if the line is gone. If the copy mode comes out ok then your outgoing faxes will be ok. You can also make a copy before you start the cleaning process as the copy with the line on it can aid you in determining what area the glass needs to be cleaned.
Good Luck and Thank You for using Fixya.
May 11, 2011 | Brother Office Equipment & Supplies
When making a copy on our Canon copier (super G3; image class MF4150) we are getting a vertical black line down the entire length of the paper. Is there something we can do to fix it? SG
You can fix this yourself by cleaning the scanner glass. When you insert a document to make a copy it is pulled in and travels over a thin strip of glass. When something gets stuck on this glass it is read or scanned as a solid line. What you need to do is make a copy. Then put that copy in the feeder the same way you put the original document in. Now the line on the copy will "line up" with the area of the glass that has something stuck to it. Use this as a guide to pop open the feeder cover, locate the glass and clean it with a cloth dampened with a bit of glass cleaner. Once you have it cleaned just run a copy again and the line should be gone. Sometimes a small flashlight helps to locate the glass.
Sep 02, 2010 | Office Equipment & Supplies
When faxing a paper and the recipient receives the fax, their copy has a wide black lines down the side....if we make a copy, it has wide black lines down the side....we have replaced the drummer we've...
FIRST I would check the scanner glass again you can test it by asking for a report to be printed..ie tx REPORT.. if this dowsnt have a line on it the problem is either the scanner glass or at worst the scanner unit it self.. I would double check the glass.. get a soft cloth and some glass cleaner on it and give the glass a good rub over. do you have the lines on incoming faxes .. if not the glass or scanner unit is the def area to be looking at, Luck A
Aug 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
I have a black line showing up on my faxed documents. I have opened it up, changed the film and re- set it, but the problem persists. The machine is about 5 years old.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
Feb 07, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Outgoing faxes are black.
just copy a paper if copy is black ur scanner is dirty or dead .first clean scanner with tissue other wise change it.if copy is ok result not black that is due to telephone line.by mian jee
Dec 15, 2008 | Brother IntelliFAX 5750e Laser Fax
Black lines on faxes
Open up the document feeder (where you put paper to send) and look for wite-out on the thin glass.
If it's not dirty, you probably have a bad scanner unit. Uneconomical to repair.
Sep 23, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
POOR COPY QUALITY
Here is the scoop! There are two (2) components to the fax machine, one is the scanner portion which is located just past where the paper you are copying or faxing enters the machine, separate the two sides and access the imaging plate, clean this area with denatured alcohol.
Step two is to clean the toner and drum unit, get the mirror at the back of the toner and under the toner. If after this you are still getting lines on the prints you will have to replace the drum unit KX FA-84 about $85. Happy faxing, Ken
May 15, 2008 | Office Equipment & Supplies
Panasonic Panafax UF-490 Plain Paper Laser Fax Logo
88 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
