Some light on; some not
disconnect power supply from the router, wait for 30 seconds , and reconnet it back then check you get the power light.. if not try in a different power outlet..check the physical connection, the modem should be connected to internet slot in the router ,so that you would find the internet light lit up.., if still you do ont see the power light or the wlan light, reset your router, if you look at the back of your router, you would find a reset button, press and hold the reset button , with a pen on paper clip for 30 seconds with the power cable connected and disconnectc power and reconnect and then check..if still not the problem is with your router
