TV not reponding to remote
I have a Philips 27T500 C101 TV that was working well, but one day when adjusting the PIP the TV stopped responding to the remote. Batteries in the remote check out OK at 1.43 volts each. Power button works on the TV as do the Channel and Volume buttons. But I miss the mute feature of the remote when those commercials come on !!
I bought a Philpis Universal remote but none of the program codes would make the TV respond. I was able to program other codes for the remote to control the Sharp VCR and the KOSS DVD, so I beleive the remote is OK.
Any suggestions ?
Thanks
  • 2 more comments
  • tRICKy1 Feb 29, 2008
    Thanks for your efforts. I unplugged the TV for about an hour, and when plugged in again, the remote and TV get along fine now. Go figure !
  • Anonymous Jun 22, 2008
    I have a Sharp model number 19L-M100B5 that will no longer respond to a model SZ500 8-in1 Universal Remote Control that I purchased to replace the remote that came with the TV and was lost. The SZ500 remote seems to function fine and the batteries are good. The TV simply does not seem to receive the signal from the remote any longer.
  • Anonymous Sep 24, 2008
    My tv remote is not responding to the tv
  • bspiva Jan 23, 2009
    Toshiba TV not responding to two different remotes even though batteries just changed and are new. Suspect the problem is the IR receiver on the TV. Where is the IR receiver located and how do I get it fixed?
    Genius:
  • 1,694 Answers
Remote IR LED receiver defective located on front edge of PC board.......I will get the part # for you........................T.
Posted on Feb 29, 2008
  • Vista Electronics Feb 29, 2008
    Part # 483531057454.................................T.
  • Vista Electronics Mar 01, 2008
    Great news about the reset! Be aware that the problem may re-occur.....if it does,you can try reset again before changing any parts......it is also possible to have a bad solder connect on the IR sensor leads..................................T.
I have a philips SRU3003WM universal remote im trying tn program to work on a magnavox tv model TR2510 C101 but cant find the codes to do so
The codes for Magnavox are 0807, 0002, 0502, 0919, 1914, 0224, 0430, 0247, 0402, 0408, 0109, 0715. Enter the code in the Setup and then check if the remote does any feature other than on/off.
You can search through all the codes as well. Turn on the TV. Press and hold the Setup button until the light remains lit. Press the TV button. Press Channel Up repeatedly (up to 300 times) until the channel changes on the TV. (If you miss this, press Channel Down to backtrack). Press the Mute button to set the code. Check if the TV responds to other functions of the remote. Continue the search as above if it doesn't work for all desired functions.
However if your TV was released less than 6 months before the remote was programmed or is newer than the remote, the code you need may not be in the programming.
I hope this helps.
Oct 03, 2010 | Philips Magnavox 27MS343S 27" TV
Not repond The remote control
Hi, Unfortunatly, Philips had a design flaw from the manufacturer. You will need to have it serviced by a technician,but the replacement part is called an I.R. Board. It should only cost about 2 or 3 dollars,but the labor is the main cost of the repair,which you have a warranty for.
Jun 17, 2009 | Philips 47PFL7403D 47 in. LCD TV
PIP won't turn off
I solved this problem by pressing SHIFT + 1
Mar 26, 2009 | Philips 5-Device Universal Learning Remote...
Philips TV stuck on the blue language selection screen.
unplug the TV from the wall outlet for two minutes, then try again
Nov 04, 2008 | Philips 32PT5441/37 32" TV
Phillips Magnavox model 9p5034 c101
You can get the actual remote control for that model at the following link. If your not sure which one it is just leave them a email with your model number and they will respond quickly. Heres the link.
http://servicemanuals.vstore.ca/
Aug 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
May 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Phillips Magnavox 9P6031 C101...
Find a universal remote with a menu and four arrow keys, b/c Philips is out of the original. Or, you could call Philips and find the number for one of their authorized centers - a TV repair man may have a stockpile of them from cust's who abandon their TVs.
Feb 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
362 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
