ASUS Laptop Keyboard for Asus A3, A6, A9, Z81, Z9, Z91, A3000 Logo
Posted on Feb 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace asus A3F keyboard - ASUS Laptop Keyboard for Asus A3, A6, A9, Z81, Z9, Z91, A3000
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
690
Points
Push in the four tabs at the top of the keyboard with a small flat screwdriver and prise out the keyboard, there are no sercuring screws behind.
Oleg Kurapov
Level 1:
New Friend:
  • Posted on Oct 14, 2012
Oleg Kurapov
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
690
Points
In my Asus A6Q00VM there're two screws holding the keyboard (marked on the bottom cover by letter "K". After removing them, slide the tip of a screwdriver at the top edge of keyboard to pry three spring-loaded tabs (one almost at the center and two near the corners) and carefully lift the keyboard minding the ribbon cable underneath.
Anonymous
Level 3:
President:
  • Master 2,653 Answers
  • Posted on Apr 05, 2010
Anonymous
Master
Level 3:
President:
Answers
2653
Questions
Helped
744914
Points
7663
Remove the old keyboard, locate the keyboard part numbers, purchase a new keyboard, replace.
Asus g53 keyboard lights not working
Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem. else you have to replace the keyboard.
<a href="http://www.laptopparteshop.com/asus-g53-g51-keyboard-replace.html">Asus G53 Keyboard</a>, <a href="http://www.laptopparteshop.com/asus-eee-pc-1005ha-keyboard-replacement.html">Asus 1005HA Keyboard</a>, <a href=" http://www.laptopparteshop.com/asus-k52-k52j-lcd-cable-replacement.html">Asus K52F lcd cable</a>, <a href=" http://www.laptopparteshop.com/asus-k52-k52j-lcd-cable-replacement.html">Asus K52J lcd cable</a>, <a href=" http://www.laptopparteshop.com/lenovo-g570-g575-lcd-hinges-replacement.html">Lenovo g570 hinge</a>, <a href=" http://www.laptopparteshop.com/ibm-lenovo-b570-g570-v570-z570-keyboard-repalce.html">Lenovo g570 keyboard</a>, <a href=" http://www.laptopparteshop.com/ibm-lenovo-g550-keyboard-replace.html">Lenovo G550 keyboard</a>, <a href=" http://www.laptopparteshop.com/sony-vaio-vgn-ns101el-keyboard-replace.html">Sony Vaio VGN NS101EL keyboard</a>, <a href=" http://www.laptopparteshop.com/sony-vaio-vgn-ns101el-keyboard-replace.html">Sony Vaio VGN NS101EL keyboard</a>, <a href=" http://www.laptopparteshop.com/hp-g42-laptop-cpu-fan-replace.html">HP G42 fan</a>, <a href=" http://www.laptopparteshop.com/hp-g62-laptop-cpu-fan-replace.html">HP G62 fan</a>, <a href=" http://www.laptopparteshop.com/hp-g62-233nr-234dx-cpu-fan-replacement.html">HP G62-233NR fan</a>, <a href=" http://www.laptopparteshop.com/gateway-nv52-nv78-cpu-fan-replacment.html">Gateway NV52 fan</a>, <a href=" http://www.laptopparteshop.com/gateway-nv52-nv78-cpu-fan-replacment.html">Gateway NV78 fan</a>, <a href=" http://www.laptopparteshop.com/gateway-nv52-nv78-cpu-fan-replacment.html">Gateway NV56 fan</a>, <a href=" http://www.laptopparteshop.com/lenovo-a600-cpu-fan-replacement.html">Lenovo A600 fan</a>, <a href=" http://www.laptopparteshop.com/samsung-r60-r70-keyboard-replacement.html">Samsung R60 Keyboard</a>, <a href=" http://www.laptopparteshop.com/samsung-r60-r70-keyboard-replacement.html">Samsung R70 Keyboard</a>, <a href=" http://www.laptopparteshop.com/toshiba-t135-t135d-keyboard-replacement.html">Toshiba Satellite T135D Keyboard</a>, <a href=" http://www.laptopparteshop.com/toshiba-satellite-e205-keyboard-replacement.html">Toshiba Satellite E205 Keyboard</a>
I am tryin to figure out what type of motherboard i have and compatable ones i can use. i have an asus g72g series
Asus G72gx Series Laptop Part Replacement:<br>
<a href="http://www.laptopparteshop.com/asus-g72-g72gx-keyboard-replacement.html">Asus G72gx Series keyboard replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-g73-white-keyboard-replacement.html">Asus G72gx Series white keyboard replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-a52-k52-g51-g60-g72-g73-series-backlit-keyboard.html">Asus G72gx Series backlit keyboard replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-g72gx-battery-replacement.html">Asus G72gx Series battery replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-g72gx-cpu-fan-replacement.html">Asus G72gx Series cpu cooling fan replacement</a><br />
<a href="http://www.laptopparteshop.com/asus-g72gx-lcd-hinge-replacement.html">Asus G72gx Series laptop hinges replacement</a>
<a href="http://www.laptopparteshop.com/asus-g72gx-lcd-cable-replacement.html">Asus G72gx Series video cable replacement</a>
How do I replace Asus A6f keyboard
Hi Friend,
Are you searching service centre Address where you can replace the Keyboard? if it correct then visit
http://support.asus.com/service/service.aspx?SLanguage=en-us
click on ASUS Global Service Center
As per Your Country you will service centre contact Details
2helpful
Properly connecting the mic cable to the pins. my mic is currently in a state of repair due to the absence of the original cable.
For low impedance A3F/A3M, two wires with Shield
Pin 1 is ground/shield
Pin 2 is hot or +
Pin 3 is cold or -
For high impedance A3F/A3M, one wire with Shield
Pin 2 is hot
Pin 3 is not used.
Keyboard Issues
I hate to say it, but you may have to go back to the company that sold this to you because the MSI keyboard should be a perfect drop in replacement.
3answers
Which notebook to buy?
I'd ask your professors which one they recommend and if they don't have a recommendation ask them what they use or better yet what they would like to use if they could afford it!
good colleges should recommend a compatible laptop that will easily sync with their school system!
Model A3F cant start at all this morning. Press ON button but nothing happens no sound whatsoever.
If you are plugged into a power strip you might try plugging it directly into the wall. If there is an on off switch on the back of the machine near where the power cord plugs in, be sure it is in the on position. If this does not help, I would suspect a bad power supply in the computer. Not too expensive.
13helpful
3answers
Removing keyboard for ASUS A9rp
There are three little clips at the very top of the keyboard itself, if you lightly push them in starting at one side while very lightly prying on the keyboard you can lift it out and then just unhook the ribbon cable. That's it, really simple actually!!!
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
