Question about NEC VT47 Multimedia Projector
NEC VT47 Lamp type VT70LP will not power up 2 red lights spear Lamp not working
Hi all I have (2) NEC VT47 Lamp type VT70LP, one of the NEC VT47's stoped working so I took the lamp out of the good (2nd) NEC VT47 placing this Lamp into the (1st) projector that had failed to power up.
The problem is that the other lamp did not reset the lamp red light plus the system still will not power up also will not reset the lamp red light.
the two 2 red lights displayed are Power and Lamp.
I run the system with no lamp but all this did was make the status light flash 2 or 3 times and then stoped flashing I then put the good lamp back in but still no change as the Power and Lamp light still glow red
Is there some kind of bios reset jumper in this projector at all or is the system dead.
You can download a pdf of the manual from here:
www.support.nec-display.com/dl_service/data/user_manual/ENGLISH/VT670/vt70s_manual_e.pdf
Also here:
www.iusb.edu/~libg/ims/VT570_MAN.pdf
Thanks for your time all any help on this would be ever so greatfull.
  • 3 more comments
  • Darryl Bennett Feb 28, 2008
    Hi Gigatech, Jaime867 and mn-tortoise thanks for your replys;
    Gigatech
    [Quote]
    For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :] [end Quote]
    Thanks for that Gigatech and Jaime867 page 55 did the trick I can not belive that, missed that info on how to do that as I read the Manual 4 or more times and still missed it LOL :)
    mn-tortoise page 50 this would only work befor the lamp has gone over" 3000 Eco" force shut down . Because the system had gone into force shut down mode I was not able to use the menu function. Thanks for your input :)
    Thanks for your help and input all, you all done a top job 10 out of 10
    Thanks all SprinterOz
  • Anonymous Oct 16, 2008
    lost the remote and conn,t get to power up
  • Anonymous Nov 21, 2008
    Lamp burnt out
  • Anonymous Apr 29, 2009
    I lost my remote too... any ideas?
  • Anonymous Mar 25, 2014
    flashes 6 times
  • 259 Answers
When the lamp exceeds 2100hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
Posted on Feb 27, 2008
    Problem Solver:
  • 18 Answers
Did you reset the Lamp Hour Meter through the menu? Check page 50 in the manual for more info. That should turn the lamp light off.
Hope that helps.
  • 2,323 Answers
Have you tried to reset the timer on the one that does not show signs of life after power up?
Page 55 shows you how to reset the timer.
Try it.
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
HI? HOW TO PUT MY IMAGE UPSIDE DOWN AFTER A CEILING MOUNT NP210G NEC BEAMER.? THANKS, Noel Belgium.
hi,
1. press menu button
2. select setup
3.go to orientation (This sets your image for your type of projection. The options are:
desktop front projection, ceiling rear projection, desktop rear projection, and ceiling front projection.)
ok,
Dec 17, 2010 | NEC VT47 Multimedia Projector
Lamp light stays on after new lamp has been installed and have used remote to try and restart by pushing and holding off button and exit buyyon ?
Select Menu option locate the selection for STATUS on the menu....you should be able to resent the lamp hours from here and signify manually that you have changed the bulb...hope this helps!!
Mar 11, 2010 | NEC VT47 Multimedia Projector
Hd flashes every few minutes
THE DEVICE THAT HELPS THE SYSTEM FROM OVERHEADING MAY HAVE BURNED OUT IT IS SOME TYPE OF TRANSISTOR THAT HAS PHOTO CELLS IN THE COMPONET TO KEEP THE SYSEM OPERATING PROPERLY.
YOU CAN GO ON LINE AND TYPE THE FOLLOW INFORMATION IN THE ADDRESS BAR
NEC VT47 MULTIMEDIA PROJECTOR LIGHT FLASHING
ENTER
THIS IS TO SEE IF ANYONE ELSE IS HAVING THE SAME PROBLEMS AS YOU AND WHAT THEY HAD TO DO TO FIX THE PROBLEMS.
ROD GANDY
Feb 10, 2009 | NEC VT47 Multimedia Projector
Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Apr 01, 2008 | NEC VT47 Multimedia Projector
NEC VT47 Blink Sequence but not comming up.
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
Feb 08, 2008 | NEC VT47 Multimedia Projector
Status light blinking red
Oct 23, 2007 | NEC VT47 Multimedia Projector
NEC VT47 lamp won't light
According to the manual, yes . . .probably gone past the recommended hours of lamp use. Press the OFF or the HELP button on the remote for 10 sec, this will reset the lamp hours value and allow the unit to come on. If it don't, NEC will tell you that it has to be sent to a repair center.
Aug 29, 2007 | NEC VT470 Multimedia Projector
NEC VT47 Multimedia Projector Logo
2,684 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
