Computers & Internet Logo
Posted on Feb 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can not add or remove a program from my computer.
When I click on add or remove program on my gateway desktop computer I get an error message "Restriction This operation has been cancelled due to restrictions in effect on this computer. Please contact your system administrator."
What can I do to fix this problem?
Thanks,
F. Boyd
[email protected]
Anonymous
Level 2:
Sergeant:
  • Expert 319 Answers
  • Posted on Feb 27, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
319
Questions
Helped
133343
Points
888
Log off and Log back on as an administrator. You are most likely logged on as a user with limited privilages.
Gateway laptop error
Which operating system ?
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
Error message
There is a program attempting to run from that drive, apparently toy 2.)
I assume you are running Vista today (confirm).
Start button>in the search area type msconfig then click run
Click the startup tab disable (uncheck) any program labeled that.
remove the program
Start button>control panel>program add/remove> select the program and uninstall.
Hello, HP's printer technicians screwed up my new
That's pretty crazy! I would have told you to turn the printer off, and unplug it from power. Same thing with the computer. Then follow a few basic procedures.
Better grab a cup of coffee, this is going to be a long one.
I have no idea what changes, the 'tech' implemented on your computer. Would have to undo what the 'tech' did step by step.
I do know one thing, however. Using the Restoration Disk/s, is not going to fix Adobe CS4.
We'll have to go step by step. I can only guide you if you have Windows Vista. (The HP Pavilion Elite e9180t is also offered with Windows 7)
Ready?
Printer:
Printer off, unplugged from power. USB cable unplugged from computer side.
You need to go to Control Panel>Add/Remove Programs.
(Left-click on the Windows start button, then click on Control Panel. In Control Panel click on Add/Remove Programs)
When Add/Remove Programs loads, find the HP OfficeJet software listed. Go to the right, and left-click on Remove.
If it asks, 'Do you wish to restart your computer?', the answer is NO.
Close Add/Remove Programs. Close Control Panel. Go back to your desktop screen.
Shut your computer down normally.
Unplug the computer from power. Press the Power On button in, and hold it in for a count of at least Five seconds. Let go of the Power On button.
Do this procedure two more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS back to the factory default settings. (No, do not take the CMOS battery out)
Now plug the computer back into power. WAIT 1 minute. Turn the computer on. Let Windows load all the way.
Install the installation CD for the OfficeJet printer, into your DVD drive. Install the software. If it asks you to restart your computer, go ahead, and do so.
After Windows has fully loaded again, plug the USB cable of the printer into the computer. Turn the printer on. You should get a message out of your system tray.
'Found New Hardware', and perhaps another one,
'Found Officejet printer'.
You should now have your printer back online.
Quicktime:
Go to Add/Remove Programs, Click on Change.
In the options given, click on Repair.
If this doesn't do it, go back to Add/Remove Programs, and - Remove, Quicktime. Now go to Apple - Quicktime - Download, and download the newest version for Windows Vista.
(If you need help with this, let me know)
Will add more in additional comments section.
2answers
I KEEP GETTING A MESSAGE...HP IMAGE ZONE ERROR...AND I CAN NOT MAKE IT GO AWAY
Go to control panel---> Add remove programes---> uninstall the entire HP installation. Restart the system. the message will not come.
If u want to install the HP image again then, reinstall it fresh from the HP CD.
Hi I have error message file:///C:/Program%20Files/Dell%20Support%20Center/sscommon/common/snapins/shell/ss_shell.htm?config=..%255c..%255c..%255c..%255cgs_agent% how to solve the problem
You can remove the Dell support from your add/remove programs. This support is installed on all Dell systems in factory. Once your warranty runs out, it is pretty worthless because you still have to pay for support.
Go to start, control panel and click on add/remove programs.
Look for Dell Support or help and uninstall it. Reboot computer and the error message will go away!
Start up problems
did you add any device recently or installed a program before this happened? If your response is yes, then take out the device and try to restart. else, retsrt your system and press the F8 key to show you the boot options. start the computer on safe mode, and remove the newly installed program or roll back the system to a safer date when your system had no problem. Cheers!
My computer is extremely slow
1. Uninstall Unneeded Programs (Start, Settings, Control Panel, Add/Remove Programs) Keeps at least 10% of your HDD free, 20% is preferred. Windows uses this space for it's swapfile.
2. Scan Your Hard Disk for Errors. (Double-Click MY COMPUTER, Right Click C:, Properties, TOOLS TAB)
3. Scan for Viruses (If you don't have an updated and functional AV, http://free.grisoft.com)
4. Check for Spyware and Adware (http://www.download.com, Spybot search and destroy)
5. Defragment Your Hard Drive (Double-Click MY COMPUTER, Right Click C:, Properties, TOOLS TAB)
6. Adjust Visual Effects for Better Performance (Right-Click the MY Computer Icon, Properties, Advanced TAB)
7. Stop Programs from starting on Windows boot (Start, RUN, MSCONFIG)
Unable to remove installed software from the computer
Go to your control panel and double click on "Add Remove Programs". A menu will pop up indicating all the programs on your computer. click on the button to remove "uninstall" the media player. You can reinstall later when you want.
Error c-0072
This error message might occur if you have the WinTools Easy Installer program on your computer. Follow the instructions below to remove this program.
  1. Click Start , Settings , and then Control Panel .
  2. Double-click Add/Remove Programs . The Add/Remove Programs utility opens.
  3. Locate the WinTools Easy Installer listing and click it to highlight it.
  4. Click Remove .
  5. Close the Add/Remove Programs utility.
  6. Try installing the HP software again.
After this it will definitely work.
1helpful
Quickcam
Error 2711
When receiving the 2711 error during Logitech QuickCam/Image Studio software installation, please perform the following steps:
  1. Use Add/Remove programs in the Control Panel to uninstall any current installation of QuickCam/ImageStudio software. For Microsoft Windows 95, 98, ME or NT
    1. Click Start, Settings, then Control Panel.
    2. Double click the icon labeled Add/Remove Programs.
    3. Highlight the desired program in the list provided (QuickCam or ImageStudio).
    4. Click Add/Remove Programs located in the bottom right of the list provided.
    For Microsoft Windows 2000 or XP
    1. Click Start. followed by Control Panel.
    4. Click the button labeled Remove located in the bottom right of the program selected.
  2. Navigate to C:\Program Files\Logitech.
    1. Double click the icon on the desktop labeled My Computer.
    2. Double click the icon labeled C:\(computer name).
    3. Double click the yellow folder labeled Program Files.
    4. Double click the yellow folder labeled Logitech.
  3. Delete any folders for QuickCam/ImageStudio.
    1. Select the yellow folder with the QuickCam or ImageStudio names.
    2. Click the menu options for File, followed by Delete.
    3. Repeat for any other QuickCam/ImageStudio folders.
  4. Delete all files located in the Windows temporary directory C:\Windows\Temp or C:\WinNT\Temp
    3. Double click the yellow folder labeled Windows or WinNT.
    4. Double click the yellow folder labeled Temp.
    5. On the menu across the top of the window, click Edit followed by Select All.
    6. On the menu across the top of the window, click File followed by Delete.
    7. Click OK.
  5. Reinstall QuickCam/ImageStudio
    1. Remove and reinsert the QuickCam/ImageStudio CD and follow the prompts OR
    2. Double click on the downloaded ImagStudio file.
Grand Canyon Tech
Grand Canyon Tech
