Question about Refrigerators
IV BEEN GIVEN AN LG FRIDGE FREEZER BUT IT NEEDS REGASSING CAN YOU HELP ME PLEASE
  • 21 Answers
Good Day, Roynred
With Sincere regrets, we're all capable and can all tell you unfortunately, what you have already discovered. I'm sorry to have to be the one to inform you, this is something you must have (at least from where I come from) Certification to handle the refrigerants associated with Regassing as you put it, to handle this type of repair. In addition, you would also be likely to have to be handy enough and have gas welding experience to complete the repairs properly to be able to relay on the unit for many years of sustaining cold temps unless you like warm beer... but we thank you for asking us for you're assistance, please do so again thanks, dean
Posted on Feb 27, 2008
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
Hi Iv got a Hotpoint fridge freezer iced diamond rfa52 it keeps switching on and off it seems when the fridge gets warm it turns back on my freezer is not defrosting but the fridge is then freezing again...
Okay, have you adjusted your cold temp knob inside the fridge part? There are two switches one in the freezer and one in the fridge you will need to watch it day by day until the optimum temp setting has been achieved same goes for the freezer if it defrosts that is the exact point where your freezer is at best! It takes patience so be patient and your problem will be solved! Good luck and thanks again for using fixya.com
Oct 09, 2014 | Hotpoint Refrigerators
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
The freezer colds like the bottom of the fridge and the bottom of the fridge is hot
Sounds like a refridgerant gas leak, if not to old it may be worth getting the leak fixed and regassing the unit but its a job for a professional.
Oct 25, 2010 | Samsung Refrigerators
Both sides are warmer than should be. motor running nonstop
You refrigerator needs regassing that is why things are not cooling. Your sides of fridge are hot because the motor keeps running to keep what gas is there flowing though the lines trying to cool fridge
May 25, 2010 | Maytag MZD2766GES Side by Side...
My Refrigarator and freezer are not working, Its not cold enpough
Hello, this could be a thermostat or gas problem. If the motor is running fine then I think that your fridge may need regassing. You will have to call a repair man in to help, I hope this helps.
Nov 07, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Ice & water dripping in refrigerator
Seems that you now have to little gas in the fridge.Somewhere on your apparatus there should be a factory tag where it should be info on amount of gas, prod date etc and also which type of gas to fill.
Other thing as fan not running properly,door gaskets leaking can lead to Ice build up.
High humidity and water all over inside fridge.Gas filling procedure.Make vacum(vacumpump)Fill in correct weight (grams or oz)of gas.Anyhow when you must fill gas there is usually a leak in your system and to find that i use liquid nitrogen.For this serviceman is the best option.
Regards. jan(Norway)
Feb 12, 2009 | Whirlpool GD2SHGX Refrigerator
Amana SBD 522VEBONY - fridge freezer is not staying cold -
If your freezer works after regassing...and after sometime the problem occurs again. It seems to me that there is leak on the pipes in which where the gas runs, that is why it runs for sometime after regassing, after some time the gas that was loaded during regassing leaked through the atmosphere and the problem occurs again. It would be better if you replace it with a new fridge.
Hope this idea helps.
Jan 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Hotpoint ffA71
ffa71 fridge and freezer warm and food defrosted. red light is on. Back of freezer making normal noise. Help.
Aug 27, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerators Logo
174 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
